2002 Don't know who to trust
Discussion in 'Generation 1 Prius Discussion' started by Pristina, Aug 28, 2012.
  1. Pristina
    Pristina Junior Member
    77
    Tampa, FL
    2002 Prius
    I
    Thank you! Very useful info. I will check out the PDF also
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    I don't wish to offend and haven't read your posts carefully, but I don't recommend you personally embark on the work people are suggesting, esp. if you've never done any work on cars before beyond changing burned out bulbs or an air filter and have no familiarity w/working w/high voltages.
    I'd have either a friend/relative that's familiar w/working on cars (esp. hybrids) or a trustworthy mechanic do it/help you.
    Even I don't work on my car beyond fixing/changing very minor things (e.g. changing air filters, wipers, cabin air filters, 12 volt battery, burned out lights). If you don't have the proper tools (e.g. proper sized sockets, torque wrench, etc.), you'd better get them before starting. The type of work people are suggesting is beyond my current capabilities and experience, besides not even having a torque wrench. I put together PCs myself from off the shelf components (motherboard, case, power supply, etc.) but have no experience w/high voltages. I wish I took auto shop in high school...
    I believe mellor's automotive is trustworthy (I have no affiliation w/them and have definitely never done business w/them), but it appears they are way too far for you.
  3. Pristina
    77
    Tampa, FL
    2002 Prius
    I
    Great news! While I have no delusions about the steps I need to continually make to get the car maintenance up to speed, the warning lights went off today for the first time in weeks!! Thank you to those of you who have helped me so far, I appreciate your knowledge and experience.
  4. Pristina
    77
    Tampa, FL
    2002 Prius
    I
    Hi! I just realized that I really appreciated your post but I don't think I got back to you yet. The car drives well. The only problem with operation was what Bob Wilson referred to as "Big Hand" Syndrome. That was only once after a long , high mph drive. Fuel economy seems good, probably averaging about 42 right now, which I know is not great for a Prius but I will know more over the course of this week. The battery has been sometimes going down to 50% lately and then as I focus on charging it goes back up to the top. I do realize that this means gradual loss of power.
    The warning lights went off for the first time in awhile today. A few things that might be based on what I have seen come up in this forum:
    1. This morning I cracked the windows in the car as it sat, which I can't usually do since we have rain almost every day while I work. This could have reduced the temp in the car since I live in FL, I have read that they don't like to sit in heat.
    2. I have not been running my AC since the car acted up that day I mentioned in the paragraph above.
    3. I have also read that they don't like to be topped off, which may have caused an upset before. But now that I know I will not do that again.
    I don't think the part that showed damage was 16, it was a little orange harness that connects the battery wires to the ECU, probably about 2 x 0.5 in. I will check the parts link you suggested, and I may see it there.
    Here is what I have swimming in my head at this point: As suggested, I intend to get a transaxle ATF fluid change. As I can I will try to replace that harness, and I imagine I probably have some cells that need to be replaced, so I have to choose betw a reconstructed with Gen 2 cells or to try and get some Gen 1 replacements at some point.
    Thanks for your help! I am always open to feedback/suggestions!
  5. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    Don't bother with Gen 1 cells, they are ancient. There are a ton more Gen 2 cars out there getting into accidents every day. Gen 2 cells are newer and better to begin with / lower internal resistance. I would even question any Gen packs the dealer sells.. I mean does Toyota have newer packs they sell for Gen1 with Gen 2 battery modules?
  6. bwilson4web
    16,514
    Let me suggest a couple of things:
    • limit top speed to 65 mph - this keeps the car in an efficient power region and reduces stress on the rest of the systems.
    • city driving, 38 mph or less - this lets the car stay in hybrid mode so the engine can auto-shut.
    • first 1.5 miles, 25 mph target - try to keep the speed down for the first part of the first trip of the day to allow it to warm-up without burning a lot of fuel. I cut through 25 mph posted neighborhood, a little longer, it pays off later.
    • park in shade - it is better to walk across a parking lot to find the car interior as cool as it can be for both the car and the driver.
  7. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    Can you ask the person who worked on your battery if they can point out the part on that diagram?
    Is it the thing in my attached pictures?
  8. Pristina
    77
    Tampa, FL
    2002 Prius
    I
    That might be it. It looks exactly the same. If it is any different, it would just be fewer holes, but that is probably just my spotty memory. That plugs into the ECU right?
  9. Pristina
    77
    Tampa, FL
    2002 Prius
    I
    Thank you! I have to go a little farther distance today then I have been driving lately by a few miles. I will certainly apply these. These types of ideas are really great right now since I am starting from scratch.
  10. Pristina
    77
    Tampa, FL
    2002 Prius
    I
    Actually, no. And I am quite certain they would not promote the concept. I have a few options there, including obtaining the Gen 2 cells myself and asking the guy in the next town who has already looked at my battery once to do the rebuild; or buying a reinvolt down the road. Reinvolt will obviously be more expensive, father away, a longer wait (1 week door-to-door + shipping time), and I will still have to have my guy down here install it. However, they are more reputable and my guy here has been fairly incognito lately. I don't blame him, I think it is because he has only worked on Gen 2 and newer before...but realized with my car that there are many similarities.
    I think he started to feel like I brought him a can of worms! I didn't mean to of course, I just wanted to learn and make sure my vehicle is reliable.
  11. usnavystgc
    3,159
    990
    Tucson, AZ
    Well, since you're warning lights have went away (for now), I suggest you don't jump to conclusions and start fixing stuff that you're not positive is broke. The only thing I would recommend at this point is to change the tranny fluid.
    Here's a great guide (step by step w/ pics).
    Gen1 Prius Transaxle Service
    As I said b4, I don't think there is anything wrong w/ your battery (except maybe burned wires). If there are no lights, that is a good sign but, I would recommend replacing the burned wires. Who knows, that may be your only problem.
    It seems that you are getting tons of help here (funny, that always seems to happen when a pretty girl posts here) so, I'm going to bow out b4 too many hands spoil the soup.
    Good luck with your car and I hope everything works out for you. I'm betting that it will.
    Pristina likes this.
  12. Pristina
    77
    Tampa, FL
    2002 Prius
    I
    Please don't bow out because I still need your help! Thank you for the transaxle breakdown.
    Another question: How can I get that harness and those wires? What are they called or how can I effectively describe them? Toyota didn't know what I was talking about last time, I don't think, because they quoted me over 1000 for a "Harness".
    The lights came back on yesterday but went back off except the check engine light, just an FYI.
    Thank you!
  13. bwilson4web
    16,514
    To go any further, we need codes from the Prius and not just the generic codes you can get for free from an AutoZone or other car parts store. We really need Prius specific codes, vehicle metrics, and subcodes and I don't care if they come from:
    • Scangauge
    • AutoEnginuity
    • TechStream-Lite
    • other Prius specific OBD monitors
    We call them "<uncomplementary> lights" for a reason.
  14. Patrick Wong
    18,210
    6,517
    We are talking about the orange bus bars that connect the interior of the traction battery. Those bus bars also have the module voltage sense wires that are connected to the traction battery ECU so that the ECU can keep track of module pair voltages.
    SSC 40G is a recall campaign where the Classic traction battery modules were resealed. As part of that repair, the bus bars are replaced.
    If SSC 40G was not already performed on your car, maybe you can get that done now, which would result in the dealer tech cleaning the module terminals, sealing them, and installing new bus bars.
    The part number for the replacement parts kit associated with that recall is 04003-35147. That kit will include replacement bus bars and may also contain other parts.
    The document for this recall is 56 pages long and is a 2.8 MB pdf file. If you are serious about learning more about this, provide your email address via private msg and I will email that file to you. The file is too large to post on PC.
  15. Avi's Advanced Automotive
    776
    363
    chaotic likes this.
  16. usnavystgc
    3,159
    990
    Tucson, AZ
    Well, I will do my best to continue to help you then but, you are getting great advice from Avi, Patrick and Bob. Here's my recommended course of action:
    1) We need to positively identify the part that is burned (and it seems that may be the cause of your lights coming on intermittently). My guess (and I emphasize guess) is that the insulation is degraded on the burnt wires causing it to leak high voltage and thus causing fault p3009 (which is your major fault code). Can you go back to the guy who told you the wires were burnt and ask him to take a pic of it or identify which part it is on the diagram I posted above? Or, is it the part that Avi pictured above? The bottom line is we need to clearly id which part is burnt so we can order that part and replace it or, have it replaced.
    2) You could also try to take the car to the dealer and ask about the TSB (which means a Toyota Service Bulletin, not quite a recall but similiar). If you can get them to check your service history (which is available to them and you on the Toyota Owners website (Toyota Owners Official Website: Service Coupons, Owners Manuals, Service Scheduling and More) (you will need to sign up/create an account)). If the TSB has not been performed, see if you can get them to perform it (even if you have to pay it might be worth it). The problem I have with this is, this dealer already told you your HV battery needs replaced and at this point, I'm not comfortable with that diagnosis. Maybe you can try a new dealer but, the new dealer will see the previous dealer's diagnosis.
    3) You should also (highly recommended) replace your transaxle fluid. This is one I would either DIY (with help from one of your mechanically inclined friends who has tools) or have it done by an independent shop. If going with an ind shop, provide them with a copy of the procedure I posted a link to above. This will give them confidence they can do it.
    As far as the diff between Gen I and Gen II, there are very few and someone who works on Gen II's should easily be able to work on Gen I's.
  17. Pristina
    77
    Tampa, FL
    2002 Prius
    I
    Yes, I definitely plan to get one of those, I guess from Amazon?
  18. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    TSB = Technical Service Bulletin and is NOT specific to Toyota.
    They are not necessarily at all similar to recalls. Recalls are for safety defects and non-compliance w/FMVSS. TSBs can range from suggestions for certain repairs to just an FYI (e.g. terminology change). TSBs what warranty (if applicable) would cover the repair so that it's free of charge. Recall repairs are free and mandated by law and shouldn't have any warranty expiration limitations.
    Here's an informational one, for example: http://www.nissan-techinfo.com/documents/NTB09-039.pdf.
    usnavystgc likes this.
  19. Pristina
    77
    Tampa, FL
    2002 Prius
    I
    Thank you. When I opened that up, assuming the last 8 numbers of the VIN are what they use to identify the range...my VIN is within the range.
    Additional questions regarding the recall:
    1. I know the battery was recalled and replaced in 2004. However, I do not believe it was replaced with a model that had this problem resolved. Anything I can say to effectively make that point?
    2. They have already advised replace. Per the flowchart, it says replace if needed. Are they going to ignore it for these reasons?
    3. I have called and spoken to at least 3 Toyota employees on related topics and they ignore me or don't call me back.
  20. Pristina
    77
    Tampa, FL
    2002 Prius
    I
    I am having the transaxle fluid replaced on Sun and I did plan to bring them that printout.
    I will also ask the battery mechanic for pictures of that part, but he has been a bit difficult to communicate with. I'm quite sure it is the harness attached to the wires pictured above.
    Do you think there is any chance they would go ahead with the recall procedure? There was a battery service in 2004 that the dealer said was a replacement, and corporate wouldn't admit that. I will create an account as you suggested to hopefully gain more info.
