2002 navi package VERY strange Multi-Display issues
Discussion in 'Generation 1 Prius Discussion' started by Tryyn, Feb 27, 2026.
  1. Tryyn
    Tryyn Junior Member
    Madison, WI
    2002 Prius
    Gen1 community!
    I have a 2002 with the OEM nav package and 85K miles that's having a really weird issue with the controls/displays. Car starts, runs, and does all the right Prius stuff (instant low-end torque, will run pure electric, shuts off at lights, not revving high for no reason.) 12V tests well and isn't low (vehicle gets driven once about every month, is on a battery maintainer the rest of the time.)
    The multi display intermittently just goes black, and takes a few minutes to recover. After it recovers, the integrated navigation system does not work (MAP/DEST/MENU buttons don't respond, the audio system doesn't even make confirmation beeps for those buttons, and the display doesn't even say "external device not connected", it just doesn't do anything.)
    The energy monitor will show if I press INFO, but it doesn't show where the power is going, and there's no outside temperature display. The "consumption" screen reset, and now it just shows 99.9. The Instant MPG bar doesn't move (it just shows 100 while I'm moving, and 0 while stopped.)
    None of the audio controls work unless I am playing a CD in the changer. Even then, the only button that works is AUDIO (switch between audio screen and energy monitor.) Not even the volume control works, and I can't turn the audio system on or off.
    "km/h MPH", "ODO/TRIP", and the hazard light switch work fine. The climate control also works fine, and it appears to talk to the hybrid system like it should (if I turn the defrost on, the engine will kick on.)
    OBD scanner shows no diagnostic trouble codes, but I will get an intermittent MAIN battery light on the multi-display. However, as I mentioned before, the vehicle seems to run fine (it will run on EV, and it has instant torque, it doesn't seem like the problem is the main battery.)
    All signs (except the fact that I don't have any OBD codes) point to some sort of catastrophic network failure. Has anyone else had this problem who can help me out?
    Thanks in advance.
  2. ronlewis
    ronlewis Active Member
    1,061
    206
    texas
    2001 Prius
    Maybe the screen is going out - they do that a lot as these cars get older. Nothing to be done about it unless you want to break the plastic center bezel around the entire communications center and AC vents. Almost impossible to remove that bezel without it breaking. If it's already broken, maybe you don't care busting it up more. In which case you might search the dismantlers for a used screen.
  3. Tryyn
    Tryyn Junior Member
    Madison, WI
    2002 Prius
    After briefly going blank, the screen works fine, gets plenty bright, and responds to touch. None of the physical buttons work (the touch buttons for Consumption/Energy work). If I'm playing a CD in the changer, the touchscreen buttons for forward/back/disc all work. I can't adjust the radio volume, and the AM/FM buttons don't work.
  4. ronlewis
    1,061
    206
    texas
    2001 Prius
    Yeah, before they go out completely, they go out intermittently. Some times they work, other times not. I found that they were more likely to work after the car warmed up. Start up, blank, drive for a while, turn off and start again, and it would often work. Eventually they stop all the time. Never had one lose partial functionality though.
  5. landspeed
    landspeed Active Member
    387
    210
    NZ
    2003 Prius
    I think what happens is that the computer(s) running the various functions (audio, nav, etc) can crash; they get rebooted every time you start the car, which is why switching the car off and on can make them work again. As to why they crash : a large part may be the capacitors drying out / deteriorating. In theory, you could replace all the caps, and they could work well again - this is often done in the retro computing community!
    My display is going that way; it has various type of ‘interference’, and a slow, cyclic change in brightness. As it warms up, the cyclic change speeds up and eventually goes away (almost) completely. On very frosty days, the display will sometimes ‘crash’ and just show a white background, which resolves by turning the car off and on again.
    Eventually we will be ‘re-capping’ these displays - they are in theory repairable, but it would involve removing the unit, fully dismantling it, identifying the capacitors, ordering replacements, and then many hours replacing them one by one!
  6. ronlewis
    1,061
    206
    texas
    2001 Prius
    Again, I'd warn you that you'll probably break the dash bezel trying to get to that display, and there are no replacements to be had. I've accepted that I've lost the display on some of my cars - would rather have an intact dash.
