2002 Prius Brake problem
Discussion in 'Generation 1 Prius Discussion' started by xtremebowhunter, Aug 30, 2012.
  1. xtremebowhunter
    xtremebowhunter New Member
    Massachusetts
    2002 Prius
    I have a 02 Prius and the driver's side brakes are wearing twice as fast as the passengers side. Some times if I have to stop quickly the brakes pads continue to apply pressure on the rotor when the brakes are released. After a little drive they seem to go back to normal. Is this a sign of a bad caliper or master cyl.? I know before I purchased the car the front brakes and rotors were done, but they used after market parts
  2. BenQ
    BenQ New Member
    Lancaster Pa
    I would check the caliper first. The brakes and rotors were done but the calipers may not have been.
    I'd remove the wheel, push the peddle, varify that the brake is sticking, open the bleeder a little and see if that releases the brake. If it does it could be a bad brake hose to the caliper. If it doesn't then remove the caliper and varify that the sliders aren't siezed. If all that is good I'd replace the caliper.
    Good luck.
  3. sbiddle
    sbiddle Junior Member
    29
    Alton, NH
    Do not open the bleeder valve on your Prius unless you have a tow truck handy. The brakes are not like a conventional car. Search elsewhere in this forum for more info on the brake system. Good luck!
  4. Patrick Wong
    18,210
    6,515
    It sounds like the driver's side caliper is sticking. If you allow air to enter the system upstream from the brake wheel cylinder then you will need to seek help from your local Toyota dealer to bleed the air out.
  5. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    I thought this was not the case with NHW11 Gen 1 prius...
  6. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    I'm pretty sure opening the bleeder for a second will not cause any problems.
