2002 Prius code clearing
Discussion in 'Generation 1 Prius Discussion' started by primuspaul, Dec 30, 2014.
  1. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    I'm tired of hooking up the computer to clear the same codes. Sometimes I don't get codes for months. At other times, I'll get 2 in 2 days. Seems to depend on the temperature, temperature change and humidity. I heard of using key turn cycles to clear the codes. How does this work? How many times do I have to turn the car on/off? Also, do I actually have to start the car and put it into ready mode or do I just need to turn to the "ON" position without actually starting the car?
  2. bwilson4web
    16,535
    For a transient, three times will suppress the check engine light but the code(s) remain in memory.
  3. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    It's the red triangle, not CEL. Also, do I turn key to on 3 times, or do I need to actually start the car into ready mode 3 times?
  4. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    What codes are coming up?
    TomK
  5. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
