2002 Prius Dome Light LED Bulb
Discussion in 'Generation 1 Prius Discussion' started by Blur02, May 16, 2019.
  1. Blur02
    Blur02 Junior Member
    2002 Prius
    I'm pretty new to this website and can't find if there's a place for Gen 1 Prii. If there is, please direct me to it, and I will delete this post and move it to there.
    I have a 2002 Prius, and I was looking to change out the bulb inside the dome light to a LED bulb. The previous stock bulb worked fine, but I just wanted to upgrade. While I was changing out the dome light, I also changed out the map lights and the ashtray light to LEDs.
    During this process, I burnt out fuse 17, which I then replaced. Now the ashtray light and the two map lights work great, but the dome light will not turn on. I've bent the prongs of the bulb holder, made sure the plug with the wires in it is snug in its housing, and so on. I get an occasional flicker when I'm moving the bulb around, but the bulb does not seem to stay on.
    The bulb that I bought is a DE3175 LED Bulb - 4 LED Festoon -30mm from superbrightleds. I can't post a link because of my newness to this site and lack of post history.
    I think the bulb is okay, but I'm not completely sure. Do you people know where to go from here? Thanks for any help in advance.
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    Can you try the festoon bulb in another location that calls for such?
  3. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    Although a festoon bulb will fit either way, and an incandescent bulb will work either way, a Festoon LED will only work in one direction. Try flipping it end-for-end.
    Nelsonprius and SFO like this.
  4. Blur02
    2002 Prius
    Sorry about the delay, I had circumstances that prevented me from being at a computer for a while there.
    So, it turns out that the bulb works, but only occasionally. I have to whack the dome light to properly seat the bulb/have the contacts touch in just the right way to make the bulb turn on.
    It is still finicky, so does anyone know how to clean the contacts? There seems to be some white lithium grease or something on the main slider, but I think that's supposed to be there. If it's not a contact problem, what could it be?
  5. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Try cleaning the contacts with vodka/rubbing alcohol, then use an emory board/sand paper.
  6. ChapmanF
    18,982
    A nice vigorous alcohol swabbing, or a rubber pencil eraser, ought to do nicely.
    Sanding or emery can remove not only contamination, but the plating on the contacts, making them more prone to get bad in the future.
    egg_salad likes this.
