2002 Prius losing power/revving up will not go
Discussion in 'Generation 1 Prius Discussion' started by ggr224, Sep 15, 2024.
  1. ggr224
    ggr224 New Member
    2002 Prius
    After replacing the e-clip on the shifter linkage the car will shift into drive, ect...took the dash out to inspect connections and all were properly installed. After assembly, the car started but the main battery on the dash display showed it was not charging from the ICE to the battery. I took the car for a test drive but there was no power whatsoever and the RPM's were up but the car wasn't going anywhere. After shutting the car off it would not start again or move when put into drive or reverse. Turning the key supplied power to everything but the car would not move as it would before and the ICE was not starting. Any suggestions will help....thank you in advance.......G
  2. Tombukt2
    Tombukt2 Senior Member
    13,826
    2,510
    Durham NC
    And how much driving did you do anything in miles or feet? Sounds like the engine may have been trying to start but it didn't actually start Not really sure what this model.
