2002 Prius Slips Into Neutral
Discussion in 'Generation 1 Prius Discussion' started by Benmuir, Dec 19, 2013.
  1. Benmuir
    Benmuir New Member
    2002 Prius
    I
    So I am getting really sick of my 02 Prius...it only has 124k miles on it.
    So what is happening now is that I'll be driving when all of a sudden the car slips into a neutral mode. The engine revs when I hit the accelerator but produces no power. So I pull over, throw it in Park, turn the car off, and when I restart, it is back to normal.
    I have seen forums on here about this but have not found the culprit...
    These are the codes I'm getting...I know this slippage is only one of my problems..
    p1437
    p3191
    p3006
    p3011
    Question:
    Does anyone know what this is? And is it a simple fix?
  2. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    WOW, that stinks. When was the last time the ATX fluid was changed? Does seem like it may be electrical if is acts normal after shutting car off. I searched and saw a thread is what causes this it's the shifter assembly, bad contacts. also saw this thread:
    Transmission Slipping !!
  3. Patrick Wong
    18,210
    6,517
    1. You need to replace the traction battery.
    2. You need to clean the throttle body interior and throttle plate.
    3. You need to replace the accelerator pedal sensor.
  4. bwilson4web
    16,535
    Please update your profile or post the nearest city and state where you live. The reason is we can recommend independent Prius shops that will have the tools and expertise to help diagnose the problem. You don't have to use them but at least you'll have more resources.
    With one minor exception, I agree with Patrick's suggestions:
    I would like to see more details about the traction battery health. I prefer seeing the 19 module-pair voltages before calling for a replacement.
    Also, I would probably want to look at the 12V battery voltages, measured at the terminals, both powered off and with the car in "READY."
  5. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    Your battery deffinately needs to be repaired,that will make it go into what you call "transmission slipping".I would personally start with the traction battery and clean your throttle body. Your accelerator pedal code may also be a product of your traction battery..Keep us posted and let us know where you are located please..
  6. Benmuir
    Benmuir New Member
    2002 Prius
    I
    UPDATE:
    Just replaced my Traction battery and have only been driving for a little bit with it and there has been no slipping yet. Ill update in a month or so
    yotatoter likes this.
