2002 Prius wanting to buy HID conversion kit
Discussion in 'Gen 2 Prius Accessories & Modifications' started by myfootsmells, Oct 9, 2006.
  1. myfootsmells
    myfootsmells New Member
    Pasadena, CA
    2002 Prius
    i'm looking to purchase an H4 HID conversion kit for my 2002 prius. has anyone done this before? is it going to affect the battery in any way?
    mods: wasnt sure if this was the right forum, please move if necessary.
    thanks
    myfootsmells
  2. Tideland Prius
    16,443
    Not that I know of. It shouldn't affect the battery since it uses less power. Just note that with these kits, your whole headlight compound will light up (like those RSXs with HID kits) so instead of a nice cut off look like you see on the current gen, you'll have a nice bluish shape of your headlight.
    Anyway, just make sure you have space for the ballast and what not.
  3. mrbigh
    3,686
    699
    Long Island, NY
  4. silentak1
    silentak1 Since 2005
    893
    28
    LA
    I've done this on my '05. Keep in mind that it is illegal because your (halogen) headlight housing will emit a pattern not too clean with some glare even after adjustments.
    I do believe it consumes less electricity once running (35watts) compared to the standard (55w). I have a dual beam meaning that there's an HID bulb and halogen bulb next to each other... the halogen does nothing in terms of extra illumination so its only function is to cause attention via high beam. Is this clear?
    Anyway, I bought mine on ebay. Out of the "cheap" but decent kits are McCulloch and Bohmen. Phillips is by far the best, but expect them in the $400+ range for single beam.
    By retrofit, did you really put a projector housing into your Prius housing? All I did was install the HID kit and pointed my headlights a bit downwards, but this isn't really retrofitting.
