2002 Prius waring lights
Discussion in 'Generation 1 Prius Discussion' started by Ptilonorhy, Nov 26, 2016.
  1. Ptilonorhy
    Ptilonorhy New Member
    Springfield, il
    2002 Prius
    I have a 2002 prius that is acting very strangely. The car drives! fine, and has been since I bought her. The only thing that concerns me is that the warning light has come on at random times. Here's what I know.
    Her coolant pump went out around September Las year, and was shortly replaced. It is working now.
    Her brake fluid is full but I suspect the back breaks need to be replaced.
    I have never seen her battery below half when she throws up warning lights recently. The volt meter reads normal every time.
    She's late for an oil change. (Very late) but her oil level is very good.
    Have not taken her in for code check.
    ___Warning lights come on:
    After driving for 18 miles. Car started slowing down with foot on gas. Putting her in park and a restart fixed it, except for the warning light; which was still on.
    After driving 24 mules. Just a warning light. Was able to drive 1 more mile without difference in preformance. Then shut the car off.
    Drove 20 miles, then slowed down. Again, car started back up running fine with the warning light on.
    __More info? Just ask. I appreciate any and all replies, regardless of whether you suggest troubleshooting or fix my problems!
  2. ChapmanF
    19,060
    She really, really wants you to ask her why she is lighting the warning light (and to stop calling it "random", that really bugs her).
    You can ask with a Mini VCI / VxDiag or by going to the dealer and letting them ask.
    -Chap
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    You'll want to get the diagnostic code.
    Then report back here.
    That will help point us in the right direction as opposed to randomly guessing.
    Some auto parts stores will read the code(s) at no charge. Else try a mechanic that works on Toyotas.
  4. Ptilonorhy
    Springfield, il
    2002 Prius
    I appreciate the feeback! She'll have her codes read first thing tomorrow.
  5. Ptilonorhy
    Springfield, il
    2002 Prius
    Okay, this morning, we took her to autozone.
    This is what they said:
    P0440
    P3191
    She also needs a tune up.
  6. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    P0440 is simply an evaporative emission code. Often can be as simple as a loose gas cap.
    P3191 can be kind of generic especially if the car needs a tune up in general.
    Start with the tune up, clear the codes, and then see if they return.
    If this is a car you plan on keeping for a while, at this age you may want to own your own set of diagnostic tools.
  7. ChapmanF
    19,060
    Yup, those make sense. The P3191 just means she's been having to crank the engine longer than she wanted to before getting it to start (keep in mind that can happen while driving, too, since the engine stops and restarts), and the P0440 refers to the evaporative emissions system, which involves a small clump of sensors and valves and vacuum hoses (and also needs the fuel tank to be leak-free). She only does evap system self-exams occasionally and under certain driving circumstances, so that's why you weren't sure of a pattern in when the light came on.
    These days, a "tune up" really isn't a thing the way it was in the old days, when engines had a lot of parts with short lifetimes or needing regular adjustment, and instead of diagnosis, you'd basically just have a big day of putting in new stuff and redoing adjustments, and be running like a top again.
    In a modern engine like the Prius, most of the parts have crazy long expected lifetimes, and it would be unnecessary and expensive to go replacing all the everythings just because some issue has developed somewhere. It's more effective now to do targeted diagnosis of the issue, then replace/fix whatever needs to be replaced/fixed, and call it a day. As you see from the codes, she can make it really easy for you to know where to start looking, if you just ask her.
    I would definitely start by sleuthing out what's causing the P0440. There are a bunch of possible causes (the manual has a nice six-page procedure you can follow to pinpoint what caused it). One of the easiest ones to check is a loose fuel filler cap (when she does her self-exam, she needs to find the fuel tank airtight).
    After that, there's another possibility I would definitely look at: Gen 1s have had a rust issue in the fuel filler neck itself where it passes above the rear wheel. The wheel kicks water (and winter salt) up in there, it sits on the steel filler neck and rusts it. She'll notice, with a P0440, because the tank's not airtight any more, but worse than that, the water kicked up by the wheel runs down in the tank and dilutes your fuel, giving you rough running and hard starting, which she has also mentioned.
    People who have replaced the filler neck say it's not too hard.
    -Chap
    #7 ChapmanF, Nov 27, 2016
  8. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Regular OBD2 readers can scan but can't do a complete scan. A mini VCI uses Toyota software and will give you more complete scans and more information. Sounds like your experience level suggests that you should take it to a Toyota shop or a good Prius oriented hybrid independent shop and let them do the scans and investigation.
    I've been doing my own work on my vehicles for almost (!) fifty years and you can cheat on oil changes and other maintenance. But as the old Fram Filter commercials used to say, "you can pay me now or you can pay me later." Good maintenance is the gift that keeps on giving.
  9. ChapmanF
    19,060
    The necessary codes were read in post #5.
    I still think the filler neck would be a definite 'person of interest', if filler necks were people.
    -Chap
  10. MDNHW11
    MDNHW11 Junior Member
    2001 Prius
    I'll also vote on the filler neck. I found it very easy to do on mine.
    Wait at your peril. Water in the tank does not a happy fuel pump make. It also leads to rust in the fuel line, which makes for injectors that weep fuel.
  11. DRACO
    DRACO Member
    362
    78
    Rancho Palos Verdes, California
    2002 Prius
    +2, Change Plugs, Air Filter and Gas Cap Oring, disconnect battery neg side then after all repairs, reconnect ( immobilizer reset ), turn key to on position ( do not start ) for 20-30 minutes, listen for water pump flow turbulence then turn off, remove the key and open and close the door. Start the car take her for a 20 minute drive.
  12. ChapmanF
    19,060
    Hmm, I'm pretty sure the 30-minute immobilizer reset is not something that is ever needed unless you have replaced either the HV ECU or immobilizer ECU....
    -Chap
  13. DRACO
    DRACO Member
    362
    78
    2002 Prius
    I stand corrected, I recall replacing the battery and did not have to reset. :D
