2002 Prius Wheels
Discussion in 'Generation 1 Prius Discussion' started by Mike Henninger, Dec 22, 2018.
  1. Mike Henninger
    Mike Henninger New Member
    Aquashicola PA
    2002 Prius
    Are Any Other 14 Inch Toyota Wheels Compatible With 2002 Prius Wheels ?
  2. Tideland Prius
    16,683
    5.5x14 and 4x100 bolt pattern.
    Are you looking for steelies for winter tires or a different Toyota alloy wheel? The only ones are Yaris/Echo ans Scion xA. I can’t remember if the 1992-1997 and 1998-2002 Corollas use that wheel and bolt pattern.
    Echo sedan/coupe
    https://goo.gl/images/f3UVFz
    Scion xA
    https://goo.gl/images/wQoKNX
    2004-2005 Echo Hatchback
    https://goo.gl/images/8QAoMM
    In terms of non-US vehicles, there’s the Ist (same as xA), Sienta, Raum, Passo, FunCargo, Vitz (Echo Hatchback), Platz (Echo sedan), Belta (Yaris sedan)
  3. Mike Henninger
    Aquashicola PA
    2002 Prius
    Thanks, I Just Purchased A 2002 Prius & It Has New Snow Tires Mounted On The Original Alloy Wheels. Just Wanted To Know My Options When I Switch Over To Regular All Season Tires So I Don't Have To Re Mount & Re Balance Tires.
  4. Tideland Prius
    16,683
  5. Mike Henninger
    Aquashicola PA
    2002 Prius
    THANKS For Your Prompt Response. Love MY NEW OLD Prius !!!!!!
  6. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Lots of that going on around here.
    When I had my 02 repainted at Maico, I wanted to complete the look. I got a set of nice aftermarket alloy wheels at Discount tire. Not that expensive (around $300 for all four and new lugnuts) and they look remarkable.
  7. Mike Henninger
    Aquashicola PA
    2002 Prius
    That's ANOTHER Option For Sure !!!
  8. 2002_Pri_Rod
    2002_Pri_Rod Member
    92
    69
    Forestville, CA
    2002 Prius
    I also updated rims and tires - bought 15 inch rims and tires from America Tires here in California - 25,000 miles and going strong - look good to in my opinion
  9. 2002_Pri_Rod
    2002_Pri_Rod Member
    92
    69
    Forestville, CA
    2002 Prius
    Here is an image with the 15's
  10. Mike Henninger
    Aquashicola PA
    2002 Prius
    Lookin' REAL Good !!!!!
