2002 Prius with exhaust holes in the two piece catalytic converter!!
Discussion in 'Generation 1 Prius Discussion' started by aswresm, Dec 27, 2014.
  1. aswresm
    aswresm Junior Member
    50
    2002 Prius
    I
    I have some holes in the catalytic converter of my 2002 Prius.....Has anyone find a cheap replacement solution for these expensive parts......Is it possible to weld these holes (some of them are under the Catalytic converter metal shields.....Please advice!!
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Find an independent muffler shop in your area.
    They can answer both questions........probably better than a dealer can.
    My guesses:
    They can get you a replacement a LOT cheaper than OEM.
    Trying to weld a hole in an exhaust pipe or muffler is like pounding sand down a rat hole.
  3. royfrontenac
    royfrontenac Member
    247
    99
    Kingston Ontario Canada
    2001 Prius
    Roy from canada trying to help --- I wrapped a stainless steel sheet of metal I got from a metal scrap yard ( stainless steel sink) around the body of the area with holes and held it there temporarily with a nut bolts and hole strap, before that I coated the metal sheet with a material that would allow the silver solder to melt and run between the converter steel and the patch when I heated the pipe patch. You will need an oxy act welder to heat up the patch and weld it to the exhaust.
    or you can buy a new converter that welds on but any missallignment will cause the pipe to not fit to the manifold properly
    cheap quick fix is to buy a product called inferno repair that requires high heat to cure it ( the converter gets very hot and will make a good cure) use a small stainless steel patch over the hole (under the patch put the inferno product against the hole) and the apply another coat over the top of the patch - the product cured like iron and is still working an my manifold repair after 6 months. Be sure it is the high temperature (2200 deg) material that gets harder and harder with heat. Cost about $10 per small bottle. Follow directions to allow air cure for 4 hours before starting the car for the converter to heat up and do a full cure. The inferno repair material starts off as a soft putty like material in a small bottle just mix it well and apply.
    #3 royfrontenac, Jan 3, 2015
    aswresm likes this.
  4. aswresm
    50
    2002 Prius
    I
  5. royfrontenac
    royfrontenac Member
    247
    99
    2001 Prius
    Hi Roy here from canada. Let us know how you did the repair and how long it lasts-- may help others in the future.
    Roy
