2002 Prius
Discussion in 'Generation 1 Prius Discussion' started by Elchanan, Aug 11, 2025.
  1. Elchanan
    Elchanan New Member
    Grand Prairie, TX
    2002 Prius
    Howdy,
    I just inherited a 2002 Prius with under 164k miles and it has a dead 12v battery. I called the toyota dealership and they told me to get a S46B24R, which come to find out is the second gen battery.
    I've seen conflicting things on here about what people are using for Gen 1 batteries, some people use L&G AGMs and some use 51R AGM
    what do y'all recommend?
  2. Trombone
    Trombone Active Member
    389
    130
    Allentown, Pennsylvania
    2002 Prius
    I've used a regular ol' 51R battery, nothing fancy, no AGM. Years ago I converted the Prius battery clamps to SAE size so I could connect to any domestic car battery. I'm currently using a lawn tractor battery from BatteriesPlus: https://www.batteriesplus.com/productdetails/sliu1rxhd. You can bolt directly to the spade lugs or get conversion hardware.
    There are similar, cheaper batteries from other sources, e.g., Walwart.
    VintagePrius likes this.
