2002 with codes random misfire clynder 1 and 2 misfire
Discussion in 'Generation 1 Prius Discussion' started by Cooter, Dec 28, 2017.
  1. Cooter
    Cooter Junior Member
    2002 Prius
    Hey I got a 2002 Prius that keeps shooting codes for random multiple misfire and misfire clynder 1 and 2 just replaced coils and plugs and it is still doing had it hook up to my code reader live feed to see rpms and if I rev it over 1600 the misfire goes away and it drives fine any thoughts
    52,889
    what code reader are you using?
  3. Cooter
    2002 Prius
    Bosch 1050
  4. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    1. Since the misfire was only on cylinders 1&2, have you done a compression tests on the cylinders to compare compression pressures? If cylinders 1&2 varies widely with the other cylinders, you either ha e a worn piston rings, or the top gasket has a failure on those particular spots.
    2. Have the fuel injectors on those cylinders checked.
    A clogged Injector system, would have a misfiring codes, as you do. Notice, sometimes, it could be intermittent.
    3. Intermittent electrical harness injector problems.
    A failed singanl voltage wire harness from the fuel injector connector to the ECU may have shorted partially. So, even if the spark plugs, ignition coils have being replaced, the issue would still persist.
    4. Weak valve cover gasket. If you have a brittled valve cover gasket, engine oil would sip straight into the spark plugs port, and foul the plugs with engine oil.
    PS: Try swapping the 1&2 spark plugs to numbers 3&4, and see what happens. If you still ha e same issues on em, the concerned spark plugs might have some hairline cracks on their ceramic insulator.
    Also check to ensure the ignition coil connectors are properly connected.
    Legends:
    1st picture: Fuel injectors from gen2
    2nd picture: Sample ignition coil on RX 400h
    3rd picture: Valve cover gasket on a rav4
    Dxta
  5. Cooter
    2002 Prius
    Just wanted to let everyone know I change the injectors and it runs fine now
    Raytheeagle and Prodigyplace like this.
