2003 Gen 1 with P3000, Battery control system malfunction
Discussion in 'Generation 1 Prius Discussion' started by Paul Baillie, May 12, 2018.
  1. Paul Baillie
    Paul Baillie Junior Member
    Hilo, Hawaii
    2003 Prius
    I
    I have a 2003 with 86K on the clock, I just put a refurbished HV Battery in it then, on the drive home the check engine light came on, its was the inverter coolant pump, replaced it with one from a parts car I have. After bleeding it it was fine for about 100 miles, then the red triangle came on so I drove it to the shop that swapped the HV Battery (my cheap code reader said no codes, their $10K unit came up with P3000 and sub-message "Battery control system malfunction" I left the garage and the red triangle went off and hasn't come back on in 40 miles> a little more info, the Hybrid display screen is very fuzzy and does not give any information except in the consumption mode where it always shows full bars and 99.9 MPG. Any thoughts on any of this?
  2. tada
    tada Member
    73
    77
    Tucson, AZ
    2002 Prius
    I’m going to lean towards the battery ECU. Maybe when the HV battery was swapped, something was hooked up wrong. Just a guess, maybe some more senior members will pipe in.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    P3000 is a generic code from the hybrid ECU;).
    There will be subcodes leading you further down the path of diagnosis:).
    There are a couple of ways to get those, but having an old laptop running Techstream software gets that information so you can research the cause;).
    Keep us posted (y).
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I'd suspect the "new" rebuilt pack; it's not unheard of for these to fail immediately after install.
    Raytheeagle likes this.
