2003 need help please
Discussion in 'Generation 1 Prius Discussion' started by David Kleinwolterink, Jul 8, 2015.
  1. David Kleinwolterink
    David Kleinwolterink Junior Member
    26
    iowa
    got tech stream and no codes ,at times very poor accelerate almost wont go and when this happens batt indicator is at 25% ,today made 200 trip happen 1 time ,later when batt light was almost 100% got 52 mpg also
    where do I look ??
  2. bwilson4web
    16,515
    Please post the 19, traction battery voltages so we can see how well balanced they are. Also the traction battery temperatures.
    No stored codes? Was the 12V power-on, reset?
  3. David Kleinwolterink
    26
    iowa
    codes from abs c1256 c1259 and b1100 will rerun
  4. strawbrad
    953
    1,007
    I copied that from this thread, Unable to determine the cause of the triangle warning | PriusChat .
    To get to the battery live data first run a Techstream Health Check. From the results screen click on the HV Battery category and from there the data list. Please share the the results of this test.
    Brad
  5. David Kleinwolterink
    26
    iowa
    take a look
  6. David Kleinwolterink
    26
    iowa
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    First Gen Prius have a reputation for clogging up their air throttle plates with gunk.
    Have a look, and consider cleaning the mass airflow sensor while you have access.
  8. strawbrad
    953
    1,007
    The 5th line is IB Main Battery and is measured in amps. This shows if the battery was under discharge or charge when the data was collected. Your value is -0.07 amps which is basically the battery at rest. The resting module voltages are very closely grouped but that does not show the whole story. Capture the data again with the battery under charge and discharge. Then you will have data to compare.
    Brad
  9. David Kleinwolterink
    26
    iowa
    it was just at an idle
  10. David Kleinwolterink
    26
    iowa
    where are they located
  11. SageBrush
    11,627
    2,533
    Southwest Colorado
    A PriusChat search will help you.
  12. bwilson4web
    16,515
    Park so the front tires are against a curb (and nothing beyond.) Put the car in "D", hold the brake and floor the accelerator and you'll be doing a 'forced charge'. Take your measurement.
    Park so the rear tires are against a curb (and nothing beyond.) Put the car in "R" and floor the accelerator. The car is in maximum reverse load, take your measurement.
    GOOD LUCK and be careful! Practice first before trying to make measurements.
  13. SageBrush
    11,627
    2,533
    Southwest Colorado
    Again, with the brake pedal fully depressed.
    Common sense, I know
  14. David Kleinwolterink
    26
    iowa
    new data
    bwilson4web likes this.
  15. bwilson4web
    16,515
    You have a healthy traction battery:
    • First 3 temps are normal and close to 4th (inlet) - a failing battery shows a hot spot and these are good
    • Min/Max voltage range, 17.01-16.88 = 0.13V < 0.3V Toyota limit
    • Notice how the end modules show higher voltage than the middle, this is normal wear pattern
    You have a healthly transaxle:
    • 87C (Water Temp Meter) > 56C (MG1) > 49C (MG2)
    Well done!
    Save this file as a reference in case something goes 'boink' in the future.
  16. David Kleinwolterink
    26
    iowa
    Well thanks Bob ,but with no other codes ,still dont know why feels like has no power and when this happens the batt light or gauge is like
    25%,cant really give to my daughter yet ,next time it happens will pull over and hold down brake and let the batt go back up and see if this is it ??
  17. strawbrad
    953
    1,007
    Next time the car acts up fire up Techstream and record a new set of data. You should still run the discharge side of the test but your battery does appear to be in good shape.
    Brad
  18. David Kleinwolterink
    26
    iowa
    would it throw code if it was like bad gas ?
  19. bwilson4web
    16,515
    It sounds like a limp home mode.
    Accelerator?
    Code would help but we may be able to check by recording the two accelerator voltages. I have noticed the voltage will wander.
