2003 Prius - Battery Time Again (P3006)
Discussion in 'Generation 1 Prius Discussion' started by KitsuneVoss, Aug 13, 2025.
  1. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    I am getting the P3006 Code, meaning an imbalance in battery voltage, which seems to translate to "Replace Battery" from other discussion on this board. Not unexpected and I had the code once, cleared it, but seems to be coming back now.
    The battery, if "Best Hybrid Batteries" will contact me back is under warranty for almost another year. Late in the day so don't know if they will contact me today or not. Hopefully they will contact me back because I have found their communication when I last replaced the battery was not the best.
    Assuming that I replace the battery and in another year I get the code again when out of warranty, or if they never contact me back, does the battery cells causing the 3006 code usually show something physical that will allow me to know which cells need to be replaced? If not, how do I tell? Also, if I do replace cells on my own, do I need to do some kind of load balancing that is NOT automatic? If not, is it something you do through Techstream in the car? If I understand I can use 2nd and 3rd generation cells and not limited to first generation cells?
    Theoretically you can get the battery from Toyota but it is pretty expensive (~3000 + 1500 core) but I am at least going to try to milk this one as long as possible at least if I can. I just thought about that they may have been $2000 before new tariffs hit us.
  2. Tombukt2
    Tombukt2 Senior Member
    13,867
    2,520
    Durham NC
    Usually you can find the battery guy on Facebook marketplace that's a good job you just likes building batteries these guys have real jobs etc my guy chgs 499 exchange . Had really good luck with him . He can run like 56 modules at a time .
  3. Trombone
    Trombone Active Member
    389
    130
    Allentown, Pennsylvania
    2002 Prius
    If you want a complete “new” battery, see http://www.greentecauto.com. I had them do a mobile install on my ‘02 last August, with excellent results, right in my driveway. Highly recommended!
    #3 Trombone, Aug 13, 2025
  4. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    Is that link right? It redirects to an IT recycling company?
  5. Trombone
    389
    130
    2002 Prius
    Yeah, I just realized this too. If you google “greentec hybrid batteries” you’ll find their main site. Try this link: Greentec Auto | EV and Hybrid Battery Replacement & Repair
    For your '03, this page: 2001-2003 Toyota Prius Hybrid Battery Replacement | Greentec Auto
    Looks like they have a shop in Bowie, MD, too. May be close to you? In my case, I live in Allentown, PA, which is about 75 miles from Livingston, NJ, where the installer guy drove out from. Worth every penny, IMO.
    #5 Trombone, Aug 13, 2025
  6. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    Best Hybrid Batteries" did get back to me, wanting to know the code. Sent them the code and hopefully by the end of the day they will send me an invoice for a shipping box. Never knew when started buying Prius, how many battery swaps I would do.
    Edit: I have to pay shipping but they are sending me a new battery. I then send the old one back. If and when this new battery fails, I will see what other options there are. Hoping it gives me at least year and a half like the first battery while this one only lasted about a year.
    #6 KitsuneVoss, Aug 14, 2025
  7. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    This is not fun at all. Got the new battery, put it in, started the car and everything seemed okay.
    Returned the old battery. Was going to try a drive test and before even putting it in drive, got codes 3009, 3000, and C1213
    Not a happy person right now.
    Maybe damaged in shipping?
  8. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    Got the new battery. Went for a short drive. Everything seems okay at the moment. Have not put the seats back yet this time. Going to take it to work tonight and see how things go.
    ammdb likes this.
  9. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    Guardedly I will say that the new battery seems to be working. This makes the fifth battery change out with four of them in this car specifically. Going to probably send out the old battery Tuesday.
    At least this time they did NOT charge me shipping
  10. Josey
    Josey Active Member
    305
    117
    Virginia
    2003 Prius
    Check up on your 12V battery condition. Opinions about that do vary, but that's a weird collection of codes not there before (I'm guessing) that appeared after the car sat for a while (I'm guessing) waiting for the new HV pack. Again, opinions vary, but don't trust any codes in these cars if you don't KNOW that your 12V is up to snuff.
    VintagePrius likes this.
  11. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    I got a second hybrid battery and it solved the problem, at least for now.
    It also is my fourth battery for that car. problem with "reconditioned" batteries.
  12. Trombone
    389
    130
    2002 Prius
    I’m on my third replacement HV. The first was defective, and quickly failed. The second, a warranty replacement, only lasted about 40k miles. Both of those replacements were from a well-known aftermarket source whose company name rhymes with “floor pan.” The third (current) one is from greentec, and claims to use “new” ( or “newer,” depending on when I read the website) cells. Replaced August 2024, less than 10k miles yet, so far so good—-fingers crossed.
    mroberds likes this.
  13. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    Not including the one that was bad on arrival, the two refurbish batteries gave me about a year and a half each.
  14. Trombone
    389
    130
    2002 Prius
    The greentec I bought has a three-year warranty. I have high hopes….
  15. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    Mine has a three year warranty as well but they charge shipping each time. Likely still save more money than driving a non hybrid car. Since replacing the spark plugs, have been getting 48+ mpg.
  16. ArCanSawDave
    ArCanSawDave Junior Member
    2003 Prius
    SE
    My 2003 has a replacement battery from "Best Hybrid Batteries". So far I've put 65,000mi on it, installed myself in May 2022.
