2003 Prius Battery
Discussion in 'Generation 1 Prius Discussion' started by swordfish, Jan 12, 2021.
  1. swordfish
    swordfish Junior Member
    new york
    i bought a 2003 Prius battery but the terminals where to thin so how can i get the right one that i need anyone help
  2. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    Get the numbers off of your old battery and by the same one you took out of it.
  3. ChapmanF
    18,949
    The Gen 1 could have two different batteries, as described in this thread with the part numbers.
    The higher-capacity one had larger terminal posts and there was a retrofit kit available to change the car's cable terminals and hold-down to match. If your car already has the larger cable terminals, then the higher-capacity battery is probably the drop-in replacement.
    The old part number of that one, 28800-21190, was later superseded by 28800-31291, which is still available. The last one I bought, its capacity had been further improved, to 54 amp hours.
    WHCSC likes this.
