2003 Prius - Door Locks?
Discussion in 'Generation 1 Prius Discussion' started by KitsuneVoss, Jan 5, 2026.
  1. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    When I use the remote, the front passenger side door lock and rear drivers side door lock do not engage. Usually the passenger side will still unlock when i use the remote but not lock. The driver's rear will usually not unlock or lock when I use the remote.
    Any easy fixes or is it best to live with the problem?
  2. Tombukt2
    Tombukt2 Senior Member
    13,867
    2,520
    Durham NC
    Sounds like door lock motors . Or poor connections to .
  3. Trombone
    Trombone Active Member
    389
    130
    Allentown, Pennsylvania
    2002 Prius
    I have the opposite problem: front driver, rear passenger. The front is not a problem, since it opens with the key, and I always manually lock it when parking. The rear passenger lock is intermittent, but inconvenient. Last time I looked, replacement parts were available, but the work involves removing interior door panels. Could be a DIY fix, but for now I'm living with it.
  4. ronlewis
    ronlewis Active Member
    1,061
    206
    texas
    2001 Prius
    Yeah, I've owned more than 30 of these and it's rare to find one in which all the door locks work. I've never tried to swap one over from my parts car - of course, not sure if those are even good. Car was wrecked and not running when I got it. Since I can reach all 4 locks from the driver's seat, it doesn't bother me. A short person or woman might feel different. If you were here in Houston, I'd tell you to come grab these, if you want them. I already have door panels off.
  5. Tombukt2
    13,867
    2,520
    Durham NC
    I wonder if the generation 2 lock motors fit .
