2003 Prius needs actuator, tires; repair or replace?
Discussion in 'Generation 1 Prius Discussion' started by gopriusgo!, Aug 16, 2018.
  1. gopriusgo!
    gopriusgo! New Member
    2003 Prius
    hi all---deciding if i should repair or replace my sweet 2003 prius! needs about 3K in work and is worth about 3-4K. Has 185K miles. Do you think if i fix it, it will last much longer? Thanks!
  2. MDNHW11
    MDNHW11 Junior Member
    2001 Prius
    lol- I have one with a good actuator and good tires. Too bad you aren't closer.
  3. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Can you do your own work? If you can't, get rid of it. BTW, needing work & tires, it's not worth anything like $3k.
    If you can do your own work, you can probably find a used actuator in a pick n pull for about $25 and put it in yourself. Cheap. And unless you're planning a major trip, cheap tires from Walmart or Discount tire will do. Since you're new on this forum, read the sticky about who should and who shouldn't own Gen 1 Prius's.
  4. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    Mine has 185k and threw a conrod. Got another engine for £320 with 70k and just finished installing it. Everything is running great so far.......
