2003 prius newbie
Discussion in 'Generation 1 Prius Discussion' started by David Kleinwolterink, Jun 23, 2015.
  1. David Kleinwolterink
    David Kleinwolterink Junior Member
    26
    iowa
    bought on auction ,needed new batt ,put in ,most days the blue temp light always comes on ,then yesterday acceleration was like turtle mode only no light ,the batt meter was 1/4 then jump up to about 2/3 and the acceleration was fine ??
    I have had three other gen ll prius never had these kinda things
    52,863
    congrats and welcome!(y) best thing to do is get tech stream and see what codes it is reading. all the best.
  3. usnavystgc
    3,159
    990
    Tucson, AZ
    In a Gen 1, the blue temp light always comes on until the temp rises to an acceptable temperature. The Gen I's are finicky. I recommend the first thing you do when you have a problem is reset the system by cycling the ignition switch off then back on.
  4. bwilson4web
    16,540
    At most, three key cycles will suppress some error indicator lights. A true power-on reset requires disconnecting the 12V ground for ~30 seconds. This clears all codes so recurring ones can be more easily identified.
  5. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    ...and make sure you have at least 2 keys for the Gen1. If you lose your last one you are screwed.
    bwilson4web likes this.
  6. danwatt
    danwatt Junior Member
    Tennessee
    2003 Prius
    I
    Wow, after owning a 2003 for the last 7 years, and now a own a 2005, I was not aware of how big of a deal the keys were on the Gen I. They just look like normal keys. Thankfully I never lost one.
