2003 Prius P0A60 error code
Discussion in 'Newbie Forum' started by Tayfun, Apr 17, 2021.
  1. Tayfun
    Tayfun New Member
    Cyprus
    2003 Prius
    my 2003 Prius suddenly received a red triangle light and couldn't give gas when it's in Reverse or Drive mode, cooling fans for hybrid always working, on screen always only two bar hybrid charge, only in petrol use but hybrid cells working fine. On diagnose it showed me the P0A60 error code, on most forums i have seen that people say it's about inverter connections, but i couldnt be sure and wanted to know how i can confirm where the error exactly is or how i can check if the inverter connections are fine. Thanks.
    52,847
    googling shows me inverter failure. but the sure fire way is to use tech stream and the service manual troubleshooting
  3. Mongolian prius
    Mongolian prius New Member
    Mongolian
    I have a 2004 Prius with the same problem. How did you solve the problem?
