2003 Prius won't come out of Park
Discussion in 'Generation 1 Prius Discussion' started by Tedmo, Jul 1, 2019.
  1. Tedmo
    Tedmo Junior Member
    Dexter, NY
    Okay you experts, I have a problem with my 2003 Prius (having 220k miles) not being able to shift out of Park. I've scanned and read all the relevant posts I could find on the matter, and came to the conclusion last night that it would either be an easy brake switch fix or possibly a much bigger stator coil replacement--the former seemed to be more likely because I can hear and feel the transmission making changes as I move the shift lever between gears (P/R/N/D/B), but in every case I could rock the vehicle back and forth a couple inches and was able to confirm it was still in Park.
    Before anyone thinks I might be new to this--No, the Parking Brake was not engaged, and Yes I know that I have to press the brake to move the gear shift. In fact, my troubleshooting this morning prior to calling AAA to have it towed to my personal garage was to remove the lower dash cover, disconnect the brake light switch, and jumper the connector (turned out to be a purple wire to the black/yellow striped wire as opposed to black to blue that another post had provided--which was close enough for me and enabled me to actually move the gear shifter without pushing on the brake.) No success however--it remained in Park.
    So my only other conclusion that I have been able to muster from all you who are more knowledgeable on Prius matters is that it could be my main stator coil has a burned wire. However, none of the symptoms of that failure seem to match up with mine--I still can start and rev (slowly) the ICE, and only after I had toyed with this thing yesterday afternoon for awhile did the red triangle come on (and I'm not even sure how much time my son and his friends had spent trying to get it to run before I got there)--this is now my son's first car, having just got his license 2 weeks ago, so there could have been another factor that he's not fessing up about--but it was not in any accident and was courteously parked in front of his friend's house and the friend's dad said he had tried to give a go also before I was able to get there.
    Sorry to belabor my question with all the above, but does anyone have a thought why I cannot get the transmission to move from Park, even though I can hear (and even slightly feel) it 'shifting' in the transmission?
    By the way, I have personally rebuilt this traction battery twice in past years (most recent was less than a year ago), and I converted from the wimpy Toyota Aux battery to a regular car battery several years and many miles ago.
    51,113
    i no know nothing about gen 1, does the 12v aux battery load test okay?
  3. Tedmo
    Tedmo Junior Member
    Dexter, NY
    Haven't verified, but I've had many problems with the aux battery over the years and never seen this symptom. I can hook up some additional juice but I am not confident that will do any good. Gonna be a few days though as I am not close to the car right now or able to troubleshoot until Friday
  4. Tedmo
    Tedmo Junior Member
    Dexter, NY
    And thank you for your timely reply!!
  5. ChapmanF
    17,282
    Park in gen 1 is purely mechanical, via a cable from the shift lever. Park is the only shift position that works that way, and gen 1 is the only gen where it does (later gens have an electrical actuator for it).
    Makes your troubleshooting pretty straightforward.
    mroberds and bisco like this.
  6. Tedmo
    Tedmo Junior Member
    Dexter, NY
    Thanks Chapman! So do you think it really may be more of a transmission problem after all? I really don't understand the CVT, even though I am an engineer and have seen the diagram a few years ago. Does anyone believe my situation is consistent with a stator coil failure?
  7. ChapmanF
    17,282
    There is nothing about the Prius transmission that makes the Park function complicated. Especially in Gen 1. Your shift lever pulls/pushes on a metal cable that swings a lever on the side of the transmission, that moves a sturdy metal pawl inside that fits between teeth of one of the gears and holds it from turning. If you're even thinking about stator coils or other Hybrid Synergy woo-woo, you're thinking about somebody else's problem.
    mroberds likes this.
  8. Tedmo
    Tedmo Junior Member
    Dexter, NY
    Okay thanks again Chapman. That makes me feel a little better although possibly without basis. So I guess I will be looking into the transmission a little closer.
  9. Tedmo
    Tedmo Junior Member
    Dexter, NY
    Okay, ran out of time in early July before a family vacay. Back to it now and I think I have confirmed that the cable and interior linkage is all good, which is bad because I can't figure out how or where the cable enters the tranny (must be under the inverter assy). I can hear the shifter doing something inside the tranny but it's definitely not coming out of park in any gear shift position. So do I need to remove the inverter I guess? I've removed and rebuilt many batteries now, but never had to do anything with the inverter
  10. ChapmanF
    17,282
    Does look like the cable attaches near the top of the tranny, where the inverter would be in your way.
    The only place the manual mentions disconnecting/reconnecting it is under engine+transaxle removal (found in the engine section, not the transaxle section), and disconnecting it is a later step than removing the inverter.
  11. Tedmo
    Tedmo Junior Member
    Dexter, NY
    Thanks again Chap. Sounds like I probably need to get a copy of the manual you are referring - can you point me to where I can get one?
  12. ChapmanF
    17,282
  13. czunit
    czunit Junior Member
    29
    baltimore MD
    2001 Prius
    Note: I had this same problem a few months ago. Turned out my key was worn down and not allowing Park to disengage.
    Try getting a new key cut from code and see if that fixes it.
  14. Tedmo
    Tedmo Junior Member
    Dexter, NY
    I didn't really think the key trick would fix it, but for $29 I figured I would give it a try. Unfortunately, no, it did not solve the problem. I have acquired a 90 day access to the Haynes manual and will be going down and in to see where the cable/linkage is disconnected or broken. More to come when I get in there. My son is adamant that he just parked it at his friend's house that day and when he was trying to leave he couldn't get it out of park--very odd failure indeed.
  15. ronlewis
    ronlewis Active Member
    971
    194
    texas
    2001 Prius
    Gothstone compiled a manual and posted the download link here within the last two weeks in one of his responses to my posts. Forget where and can't look now. You should be able to find it.
  16. gothstone
    gothstone Junior Member
    36
    KC MO
    2002 Prius
    I admit to no such thing...
    WHCSC likes this.
  17. ronlewis
    971
    194
    texas
    2001 Prius
    Oops, that's right. I was thinking of a private conversation I had with someone here.
    WHCSC and gothstone like this.
