2004 12v battery replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by WilliamRDickson, Aug 19, 2022.
  1. WilliamRDickson
    WilliamRDickson New Member
    Port Townsend, WA
    My mother was recently given a 2004 Prius, and she’s been having some issues with accessories and instruments shutting off on her while the car otherwise drives normally. The dealer that was working on it recently needed to jumpstart it after it had sat for about three days. I’m guessing the 12v battery probably needs replacement — the original owner did most of his own maintenance, and tended to let stuff go as long as possible, so this is probably the second battery, at best.
    I think I can replace it myself…the instructions I’ve found don’t seem difficult. But reading the many battery threads posted here over the years, I’m not clear on whether there is currently a third-party drop-in replacement for the original battery. O’Reilly carries 2-3 in stock locally that claim to be right for the car, but some of the threads suggest that not every battery that works will actually fit properly.
    Can anyone recommend a specific battery that’ll fit properly? Thanks!
    iPhone ?
  2. dolj
    dolj Senior Member
    8,622
    4,376
    Wellington, New Zealand
    Basically, you are looking for an AGM battery with JIS (Pencil Post) terminals oriented with the negative post on the right. Dimensions (L x W x H =in) 9.3, 5, 8.8 (total height including terminals 8.8 in) The form-factor code is 46B24R. There are a couple of aftermarket brands that meet these requirements, but not all are necessarily cheaper than the OEM so it pays to ask around.
    A lot of cheap so called drop-ins are actually flooded not AGM so be cautious of that.
    WilliamRDickson likes this.
  3. WilliamRDickson
    Port Townsend, WA
    52,626
