2004 - antenna - lowest $ replacement?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rocketman735, Jan 11, 2019.
  1. rocketman735
    rocketman735 New Member
    Earth
    Hello,
    What is the lowest $ replacement option for the factory antenna on a 2004 Prius ?
    Antenna on my car rusted at the base (just above the nut) and broke off.
    Not looking for anything fancy or high dollar, but whatever will work.
    Thanks in advance.
    Rocketman
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Welcome to PriusChat!!
    In the upper left corner there should be a 'search' box, which currently works :cool:
    When using the search term "antenna" in one of the subordinate forums titled "Gen 2 Prius Accessories & Modifications"
    Offered these results : https://priuschat.com/search/105029124/?q=antenna&o=relevance&c[node]=49
    I remember people upgrading at the junk yard for little or nothing, and also buying other makes/models for <$10.
    Not sure if any actually increased reception one iota :(
    Please report back if you find something that improves your FM/AM options.
    Raytheeagle and KK6PD like this.
