2004 error code
Discussion in 'Prius PHEV Plug-In Modifications' started by jucabala, Jan 19, 2016.
  1. jucabala
    jucabala New Member
    boise idaho
    There's a prius for sale in my area that has the following error as pictured.
    I don't own a prius but I'm curious if this means it needs a new battery?
    This is for a 2004 prius with under 50k miles, thanks!!!!
  2. DRACO
    DRACO Member
    362
    78
    Rancho Palos Verdes, California
    2002 Prius
    That is a an odd reading. Is this what the seller is providing?
  3. jucabala
    jucabala New Member
    boise idaho
    yes, that's one of the pics on the ad
  4. DRACO
    DRACO Member
    362
    78
    2002 Prius
    If seller is legit. They should have no problem allowing you to have the dealer or Prius mechanic take a reading on their TIS scanner. If seller gives you grief about it they are screaming to you that they are trying to rip you off.
    If a local PC member is available with a TIS miniVCI, maybe they can help out???
  5. jucabala
    jucabala New Member
    boise idaho
    here's another pics
  6. DRACO
    DRACO Member
    362
    78
    2002 Prius
    Okay, that is a plug of EV. So the previous pic must mean the car is not plugged in. Okay obvious but you should get a reading prior to purchase at a minimum.
  7. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    2004 Prius doesn't plug in. this posted wrong forum
  8. bisco
    52,607
    they must have added an aftermarket ev system. be very careful.
  9. DRACO
    DRACO Member
    362
    78
    2002 Prius
    Definitely do a PPI before you buy something like that. You don't need to inherit someones frankenstein
