2004 Gen II - New Battery - Now needs new ABS Actuator?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ed Hornyak, Jun 17, 2013.
  1. Ed Hornyak
    Ed Hornyak New Member
    I
    I have a 2004 Gen II Prius with 175K miles. Last May 2012, I replaced the Hybrid battery pack for $3700.
    Since April 2013, I noticed a intermittent noise, similar to the coolant pump, but sounding as though coming from the driver's side of the engine compartment. It starts as soon as I open the driver's side door (even without starting the car) and continues, while driving also, until about 5 minutes after the Prius is turned off.
    My local Toyota service center says it's the ABS actuator that needs to be replaced at a cost of $3000. Right now, the car is showing NO codes or lights. Could this be anything else? I think it may be a relay that's faulty or software that need's updated.
    Looking for any ideas.... Thanks.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I would see about getting a used part. Since that's a lot of money to spend on a 9/10 year old car.
  3. Rich12
    Rich12 Member
    176
    29
    Right. And I might start dating Calista Flockhart. That's the ABS actuator for another $3000-$5000.
    Ed Hornyak's view of reality: "I personally believe that U.S. Americans are unable to do so because, uhmmm, some people out there in our nation don't have maps and uh, I believe that our, I, education like such as uh, South Africa, and uh, the Iraq, everywhere like such as, and I believe that they should, uhhh, our education over here in the US should help the US, uh, should help South Africa, it should help the Iraq and the Asian countries so we will be able to build up our future, for us.”
    Riaz likes this.
  4. Patrick Wong
    18,212
    6,529
    Two ideas:
    1) Do you have any driveability issues at this point? If not, and since no skid control ECU warning lights are on [such as ABS, VSC or ((!))] then why worry?
    2) If the problem gets to the point where one or more of these warning lights come on or if your brake system is impaired, then buy a used part from a salvage yard, as previously suggested.
    I think it is likely that the brake pressure accumulator within the actuator assembly is leaking pressure, hence the need for the brake pump to run more than in the past.
