2004 Loses Power In Heat
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by christopher robin, Jul 11, 2013.
  1. christopher robin
    christopher robin Junior Member
    SLC, UT
    I have a 2004 Prius, ~150k miles. At about 80k I replaced the inverter coolant pump as a preventative measure, per advice here on PriusChat.
    Recently, the car has shown intermittent lack of power, and abnormally sluggish acceleration, which seems similar to what I've heard about the failsafe mode of an overheating inverter, except no warning lights appear. We have had some hot days this summer in SLC, Utah (100+ deg). It's a sporatic issue that seems much worse on hot days. The weather has been hot, but we've had hot days in past years and not had this problem.
    Yesterday, the car showed the worst ever such behavior, and was nearly crippled for my wife (why do these things always happen when the wife is driving alone?). She was returning home from a ~ 1hr appointment, where the car was parked in the sun, ambient air temp was ~103 deg. Car was very sluggish and ICE was revving much higher than normal. The battery fan that vents next to the rear passenger-side door was running at higher speed than she's ever heard it before. I asked her at the time about the battery level, and the display showed two bars, even though she was going mostly downhill. A/C seemed to be working, but she turned it off. She was able to limp home. It did seem that when the battery charged a bit, performance improved somewhat.
    After I got home a few hours later that evening, (temp ~90-95 deg), I took it for a spin and it seemed fine. I'm pretty sure I detected a slight hiccup in power one of the times I punched it, but nothing drastic. She drove it this morning (84 deg ambient, ~75 deg overnight low) and it seemed normal, except that she could hear the battery fan (we almost never hear it running), but it was much slower than yesterday.
    If it engages a failsafe mode for a hot inverter, shouldn't warning lights come on? I haven't tried to have codes checked, but there is no check engine light, so I assume that no codes are logged.
    I have a dealer appt 1st thing tomorrow, but I'm afraid with no codes logged, nothing will be found. I was planning to take the car on a ~200 mile trip tomorrow evening too. While at the dealer, I will have them replace the inverter coolant pump under the recall (a nice way to get another free pump and coolant change). Maybe the pump I put in is having problems?
    Revving engine and low power makes me think that the electric side of the hybrid system is being overtaxed, presumably by heat. I don't know if it's related, but in the past year or so, I've occasionally noticed that the hybrid battery shows low charge (1 or two bars) after the car has been sitting overnight, without any strenuous driving the day before. I haven't been able to nail down conditions of that.
    Thanks so much in advance for any advice/feedback.
  2. Patrick Wong
    18,210
    6,514
    It is easy enough to check the inverter pump: just make the Prius READY, open the hood, and look at the inverter coolant reservoir for fluid turbulence. If you don't see this then the pump has failed. And yes, you would expect that if the inverter pump failed, that a DTC would eventually be logged as the DC/DC converter stops working and the voltage on the 12V bus sags, thus causing the master warning triangle and ABS/VSC/brake warning lights to turn on plus the hybrid vehicle icon to appear in the MFD.
    It could be that your traction battery is getting marginal but the module pairs don't evidence sufficient voltage imbalance to cause a DTC to be logged.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Sounds like the hybrid battery is going on it. And it sounds like the Inverter coolant pump has gone out again.
    Both show the same symptoms only usually the Hybrid pack will throw a code. Easy to check the pump. Put the car in READY and take the cap off the INverter coolant reservoir and look for real good agitation in the fluid.
    Mine looks like its boiling.
    Do you hear the Hybrid battery fan running in the back passenger seat area between the seat and door? Do you see fast wide swings of battery level on the mfd? From green to blue?
    If good agitation in the coolant tank good idea to take it to the dealer and they'll hook up the Techstream laptop and they can interrogate all the individual 28 battery packs for health. Make sure you tell them your concerned about the Hybrid battery pack and if possible ask to talk to the tech and express that again so they look at that closely.
    Get a paper print out of the diagnosis.
    That's $125 in my area dealer for that diagnosis.
    And to bum you out even more it sounds like the 12 volt battery is going on it too with the loss of hybrid level overnight. When you first put the car in ready do you see a momentary red exclamation point on the dash then it disappears?
  4. christopher robin
    SLC, UT
    Thanks very much for the advice. Major bummer if it's the hybrid battery. The battery fan in the back seat is indeed running much more than usual. Haven't noticed fast swings of battery level, but will look for that.
    I've read somewhere someone suggesting looking at a wrecking yard for a hybrid battery, is that advisable? Is there enough access to the cells for me to check one with a DVM, and if so, what do I check for?
    I'll check the inverter pump ASAP. I forgot about being able to check it by turbulence in the reservoir.
    When it's at the dealer tomorrow, I'll make sure to get a report about the battery status. And they'll be replacing the inverter pump anyway, so that will solve that problem if it exists.
    I replaced the 12V a couple years ago (after the transmission wouldn't shift out of park--took a while to make that connection), but I'll check it too. Interesting that a bad 12V battery would drain the hybrid battery. I would never have guessed that to be related. How does that happen?
  5. christopher robin
    SLC, UT
    By the way, what has been a typical life for the Gen2 hybrid battery?
  6. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yes but you're chasing a problem, so you really need to know for sure if the inverter pump is part of the problem. So don't run blind here, make sure you do test it. (Actually I cant see the point in replacing it if it's working,m but that's up to you).
    Once you get the inverter coolant pump sorted then the next thing to check is for fur/hair/dust obstructing the rear fan. See my photos in post #31 here: Fur and dirt causing major battery problems | Page 2 | PriusChat
  7. christopher robin
    SLC, UT
    I wondered about it needing a cleaning and lack of ventilation near the battery being the problem. Thanks for the tip, I'll check it tonight. We haven't had pets in the car or drive too much on dirt, but you never know.
    The reason to replace a coolant pump that is (presumably) working is that it is covered under the recall, and it gets me a new pump and coolant change on toyota's dime.
  8. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Unfortunately I don't think anyone here has enough data to really give a mean battery life estimate. Anecdotal evidence is that 10 years and 150k miles is where you're likely to see a definite increase of the risk of failure.
    All we know are what users report, but we don't know the true population size the reports are drawn from. So real statistics (as opposed to "gut feelings") on this are lacking. It does however *seem* that a relatively small percentage fail before 100k miles, a small but significant number fail between 100k and 150k miles, and we expect to see an increasing number failing as you go beyond 150k miles. But time is also a factor, so cars that put the miles on more quickly will in general make it to higher mileage before battery failure.
  9. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Ok yeah, that certainly makes sense. (y)
  10. christopher robin
    SLC, UT
    Took it to the dealer and nothing untoward was found. They basically said that without codes they can't diagnose anything. I told them several times I wanted a health report on the hybrid battery but the service guy said he talked to two different techs and both said there wasn't a way to check it. Said the car did that itself and if it found any problems it would log a code. Is there a specific test you know of that I can request to check hybrid battery health?
    They verified good health of 12V battery and replaced the inverter coolant pump under recall. I verified turbulence in the reservoir before that work was done, so that doesn't seem to have been the problem.
    They did report that the MAF sensor looked kinda dirty, so I will clean it ASAP.
    My wife has noticed some hesitation again, but it hasn't had major problems since that one incident. I have noticed very slight hiccups, but usually drive it only in the evening. We haven't had any more 100+ deg days.
    I basically want to catch anything that is going bad before the car strands us, if possible. So is there a known test for the hybrid battery that I can request? There are other dealers in my area I could try.
    Thanks again for the advice.
  11. Rich12
    Rich12 Member
    176
    29
    You'd have better luck at the roulette tables in Vegas or predicting the stock market than to guess a typical life span for a hybrid battery in these clunkers...
  12. edthefox5
    10,096
    4,836
    Clearwater, Florida
  13. christopher robin
    SLC, UT
    A voltmeter test of the (unloaded) 12V battery by me showed it was ok (12.37V as I recall), I will look into that more, test loaded, etc, but it seems ok. Any tests for the hybrid battery?
  14. edthefox5
    10,096
    4,836
    Clearwater, Florida
  15. edthefox5
    10,096
    4,836
    Clearwater, Florida
    Here's a really good presentation concerning the Prius from the University of Toyota. I can't link it here as its secure.
    So google:
    Toyota Hybrid Presentation Course 072
  16. vskid3
    vskid3 Active Member
    773
    228
    It sounds almost exactly the same as my Escape Hybrid when the HV battery cooling fans died. The battery would get too hot, so the computer would severely limit the amount of assist it could provide, leaving it accelerating like a slug on just the engine. I would suspect that a toasty battery is causing your problem if the inverter is getting cooled. Using the AC when its hot is a must to keep the battery cool, even if you only turn it down to ~80.
    The dealer might have a way to scan the battery temps. You can do it yourself for under $100 with the Torque app for Android. $15 for a cheap bluetooth scanner, $5 for the app, and however much you want to spend on a new/used Android phone/tablet that has bluetooth. You can see and log the HV battery, inverter, motor, etc temperatures and see which one is out of whack.
  17. theshark
    theshark Member
    164
    Martinsburg, WV
    "Clunkers"?
  18. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    The dealers are telling you the correct answer: They only fix broken things, so without a code telling them where there is a problem, nothing is broken. The typical dealer will not know a great deal about NiMH battery technology and how to predict future failures, although I would expect that there are some exceptional ones out there. The expertise available on PC is certainly more in depth than what you will find elsewhere.
    What I suggest, and have done myself, is to be proactive and get yourself set up with instrumentation: Torque, PriiDash, or the mini VCI, and look at the spread of internal resistances and voltages of the battery blocks. When you see one starting to diverge from the pack significantly, over time, then you can expect that the car will set a code before very long.
