2004 Prii owners with high mileage any problems??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bob Allen, Jan 8, 2007.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    If you read the shop manual section on that job, they warn you to use a SST to unstake the axle nut from the axle. Yes, they warn you will damage the axle threads.
  2. uvm1969
    uvm1969 New Member
    39
    I have a 2005 with 122,400 trouble free miles so far. I have not had a single maintanence issue.
    I replaced the inverter fluid and coolant at 100,000 miles. I use WIX oil filters and Amsoil XL 5 20 synthetic oil. It burns no oil at all, and I change the oil every 7,500-8,000 miles.
    I have a business friend who has put on 110,000 miles already on a 2008! He is a distributor and drives the vehicle hard every day. Not a single problem for him, either.
  3. zebibyte
    zebibyte Junior Member
    I have a 2004 with 157k now, going strong. Only thing done to it other than suggested maintenance was to replace the transaxle fluid recently. I've just noticed that both rear brake lights are failing, the LEDs are extremely dim, while the center LED strip is fine.
  4. djasonw
    djasonw Active Member
    960
    121
    Coconut Creek, FL
    Ugh...I hope it's not too expensive to repair when mine starts failing. I'm really glad to have this resource for possible future issues.
  5. zohyeahz
    zohyeahz New Member
    Virginia
    Mine has 170k on it. I have the infamous headlight problem, despite buying a $300 bulb from Toyota the first time it went out. Also, this week - my check engine light came on. First thing i'd had go wrong!
  6. fiblet
    fiblet Junior Member
    San Jose, CA
    I have an '04 with 138k miles. Original 12v battery still ok, original brake pads front and rear still ok. I did have a slight leaky rear shock at 70k miles but didn't fix it yet, still seems to be ok. I had the pain of replacing the license plate bulbs. I replaced them with LED so I would not need to do that again. I noticed on the 2010 they put small access windows to get to the plate bulbs now. The rear tail lights seem to just go off occasionally. All I do is hit the outside of the tail light with my hand and they go on again. I have to do this for each side maybe every few months. My main gripe with the car is some of the interior cheapness. This would be the armrest cloth that unglues itself and the glovebox springs that snap out from the cheap plastic holders.
