2004 Prius 12V battery--need help
Discussion in 'Gen 2 Prius Technical Discussion' started by jackson5, Dec 11, 2017.
  1. jackson5
    jackson5 Junior Member
    san diego
    I'm having trouble finding the correct Prius battery. It's time to change my prius 12 V bat. It lasted 7 years. Of course the dealer is rather pricey so I went to a couple of auto parts stores. The batteries they had (and sold me--but I returned them) were size 46 B (L=9"). The original battery in my prius is size 34B/20R (L=7.5"). The bigger ones won't fit w/o modifications. I think later Prius models, maybe even a later Prius 2004 model, had the bigger battery. Has anyone else had this problem? Can the size 46B bat (L=9") be installed with easy mods to the battery holder? Any info would be appreciated. It's a great car--235K, still the original hybrid bat and even the original front brakes!
    52,763
    do you have sks or no?
  3. jackson5
    san diego
    No SKS which may be why I have the smaller Bat.
    52,763
    yes, if you don't want to upgrade, you may have to go with the dealer. have you tried online, optima, etc?
  5. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    12V-Batterie – Prius Wiki (German Prius-Wiki):
    Original battery "small" (for models without smartkey system)
    - Manufacturer: GS YUASA
    - Type: S34B20R
    - Capacity: 35 Ah
    - Dimensions, without connecting poles (L x W x H): 190 x 130 x 200 mm³
    Replacement Battery Banner for Prius II without Smartkey System
    - Type: Power Bull P4027
    - Capacity: 40 Ah
    - Dimensions, including connections (L x W x H): 187 x 127 x 226 mm³
    - Manufacturer: Banner
    - Price: about 80,- EUR
    - Connection adapter for battery venting must be replaced with a 5.9 mm adapter (eg from BMW).
    - The battery has two vents. The opening not on the right side of the breather hose must be closed.
    - Degassing hose must be 3 cm longer than the original, as the vent is located further back.
    Replacement battery MOLL without smartkey system
    - Type: MOLL Kamina start
    - Article number: 535 020 024
    - Price: about 70,- EUR (Batterie24)
    - Capacity: 35 Ah
    Replacement battery Flybat FA35 without smartkey system
    - Type: 300A Asianype, plus left, thin pole
    - Article number: BC535111803
    - Price: 49,90 EUR (Battery Center: http://die-batterie-experten.de/)
    - Capacity: 35 Ah
    - Endpolart: 3 (Asian Pole)
    - circuit: 1 (positive pole on the left)
    - Manufacturer: "Hausmarke" Battery Center (allegedly manufactured by Varta France)
    - degassing: 2 openings, one must be taped, in the other the BMW breather (s.o.) with original hose insert
    12V-Batterie – Prius Wiki:
    Battery overflow adapter from BMW (part number 6 121 137 78 35, costs about 2 EUR from BMW)
  6. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    Yes, it can quite easily. Go get the SKS battery holder from your local Toyota Parts dept. Costs about $25. Well worth the investment.
  7. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    Or your local pick-n-pull! There's only 2 bolts that hold the hold-down bracket in place. Just look for a car with smart key.
