2004 Prius 220k miles bad hv battery & cat conv
Discussion in 'Gen 2 Prius Main Forum' started by GreenCleaner, May 28, 2014.
  1. GreenCleaner
    GreenCleaner Junior Member
    28
    Chicagoland
    I don't know where to start but my goal is to hopefully get some advice on if I should sell to a private seller or keep and fix over time.
    I currently have a 2004 Prius with ~220k miles. I went into the dealer 3 weeks ago because my dashboard lit up with all of the warning lights, my meter was shooting up and down but the car was still running fine. I checked here and immediately saw that it was potentially the hybrid battery. I mentioned all of this to the service adviser. Unfortunately he immediately shot my speculation down and stated Prius could go past 300k miles and it was too early for that. They checked my car and stated it was the auxiliary battery. They gave me a long drawn out explanation that the aux battery wasn't sending enough juice to the car to keep the hybrid battery charged. ~$300 and 1 week later the car is running fine until I leave for a week to go out of town and return to the same problem which is now 2 weeks later. I went back to the dealership today and they gave me the following (no diagnostic charge):
    P0A80
    P3020
    P0A08
    P3000
    P0420
    They mentioned that I would need a new catalytic converter. I typically go to another dealership (the one above was the closest to my house and I've never gone to) for my oil changes ($16 specials) and get a multi point inspection. They give a print out of everything I need done and I take the Prius to an independent shop that I've been consistently happy with. Both shops have seen my car and neither have mentioned the need for a new catalytic converter. The independent shop did mention some time ago that if my check engine light came back on I may need an 02 sensor after they performed a tune up.
    I'm at a crossroad of wondering if this car has life in it if the hybrid battery is repaired and is there a way to avoid replacing the entire muffler, cat converter system? If so I would love to keep it and make the repairs over the next 2 months after purchasing a new car. But I'm getting advice from non-Prius drivers that I should give it up and the car had it's run. The advice is killing my little faith in the car.
    Also I happened to stop by Carmax tonight and looked at a Prius I saw online for a decent price and miles and I let them give me an appraisal which turned out to be $750 which is so much lower than I expected. There's a few dings on the rear bumper and the front right door have a scratch from pulling out of a parking lot that had a railing I didn't see. Other than that I've done everything I was suppose to do to keep the car in good working condition. It's also the fully loaded one minus the leather seats.
    Also I found a few batteries in junk yards but they were out of state from newer 2nd gen with under 100k miles, any advice on purchasing from the junk yard?
    Any and all advice would be appreciated!!!!! Thanks!
  2. Beachbummm
    Beachbummm Senior Member
    1,160
    393
    you can sell the car for more (at least $2000) on craigs list....check out the videos on youtube on how to rebuild the battery...you can find cell's on e bay for about 40 bucks and I have never seen more then two go bad inside the battery pack. so for under $100 and about 3 hours times you can have the car running again..good luck
  3. JOE-PHBR-San.Antonio
    JOE-PHBR-San.Antonio Junior Member
    San Antonio TX
    My advise to you is yes keep the car!
    first i would just like to give you some information to explain how is HV battery work that way you know that the newer HV battery pack is not necessary to be a good battery specially if it was setting at junk yard !!so please read the following then I have some more answers for your questions regarding the catalytic converter at the end of this important information from our own experience through the years!
    **A nickel–metal hydride battery pack Gen2 or Gen3 is a chemical reactions battery that made of 28 nickel–metal hydride/electrochemical battery modules that convert the chemical energy into electrical energy.
    so Each battery module contains some chemical materials like the hydrogen and the potassium hydroxide,..These chemicals reacting through some process inside each individual battery module, these chemical reactions process will produce energy, and these energy eventually becomes an electric power within each battery module individually that will add up to produce the minimum enough power that will be translated later to voltages and capacities that can be measured as numbers with the right devices!! so in generation2 or generation3 Prius ,the minimum voltages requirement for the operation to be conducted Normally is 201.6 Dc Voltages by Toyota Standard *and since each battery module made of 6 nickel–metal hydride battery cells that connected in series and have a minimum of 1.2V x6 cells that's a 7.2V ,So each module suppose to Cary a minimum of 7.2v multiply it 7.2 V X 28 (NiMH) modules inside the HV battery pack that's The total voltages of 201.6 DC V " by Toyota standard" ,so these total voltages can supply the minimum enough power needed by any part that needs electricity power supply to perform within your Prius gen2 or Gen3 weather that power is AC or DC power needed by each different part ,then the inverter (electric motor) comes in place to do the work using its own Converter inside the motor case , so it can send a different type of electricity as needed by each part within your gen2 or Gen3 Prius .
    That process must happen in a balance ?Same time discharge at the same capacity and same time charge at the same Capacity as well !!! so if you only replace one or few modules then there will be unbalanced charging and discharging process !! that's because you put modules that carry a different capacities !! and that will work for sometime then the strongest modules will survive and the weakest modules will break down suddenly causing a red triangle !! and one or more hybrid battery pack OBD codes !! this is from our own experiences almost 5 years now !! We have upgraded our system with a newer system that imported from out of the states and allows us to get the right numbers and the correct battery balance with the exact capacity that each hybrid battery module needs !!So each individual (NiMH) battery module that we install inside any HV Battery Pack is a completely Re-manufactured (NIMH) module that we bring to a Capacity level that matches the factory battery module from Toyota using our Latest Technology and Newly upgraded computerized battery analyzer and charging system ,also We install a completely rebuilt HIGH VOLTAGE BUS BARS to insure an excellent connections with the HV-(ECU) ,Also we install the Prius Re-manufactured hybrid battery pack in one of our Prius fleet and drive it for a minimum of 50 miles to insure the quality as a final stage so at the end you can get a very reliable, quality and affordable Prius Hybrid battery pack .
    For more info please go to Prius Hybrid Battery Rebuild
    or contact me at any time if you ever encountered any issues with Toyota Prius Gen2 2004 to 2009 and I will be more than happy to assist you.Now regarding your concerns about the P0420 Catalyst System Efficiency Below Threshold,we have seen several Prius in the past when they gets any of theses hybrid battery OBD Codes codes PoA8o,P3020,P3000 they also sometimes comes with a different codes as well!!
    the only way to know is more deep diagnostics to find out about the Catalyst System and if it happens to be a bad then yes you will have to get an OEM used certified catalytic converter and that is the entire muffler since it comes as one unite !! and you can get a very decent one from any gen 2 certified one will cost you about $600 to $900 with the core !hopefully this is not the case!
    let me know if you have any more questions I will be happy to help :)
    We are open 24/7 standing by to assist and help !
    Joe
    Prius Hybrid Battery Rebuild San Antonio TX
    #3 JOE-PHBR-San.Antonio, May 28, 2014
    usnavystgc likes this.
  4. GreenCleaner
    28
    Chicagoland
    Thanks guys but I honestly don't have a place to take the car apart and leave it for a few days to redo the cell. I looked at plenty of videos and it seems pretty easy until I found out I have to balance the cells which sounds like a 3-5 day process, right? If not, any recommendations to shorten the balance time?
    Joe, you're awesome! The nickel–metal hydride explanation made more sense than a lot of the rocket science explanations I've read over the past 2 weeks lol. So would you say the cat conv can wait to be repaired? Weeks, months? Which would be better to do a deeper diagnostic, the independent shop or dealership?
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Whaaa!! $750. Don't let Carmax have it at that price. I have plenty of customers/enthusiasts who would buy it tonight at $750!!
    I would avoid junkyard packs simply because the quality is unknown. And even with a 30 day warranty, if it fails, you'll have to pay to have the failed one taken out and a new one put in.
    Not sure how close to "Chicagoland" you are, but if you are up for a trip to Madison, I could help you out. Or since I do mobile service, I could come to you. And regardless, I'd be happy to chat via phone as well.
    A good, independent hybrid repair shop would have a deeper understanding of the hybrid system than most general technicians.
    If your car has to be smog checked, then you mat be stuck taking care of the catalytic converter, regardless of whether or not you'd prefer to wait.
    Great explanation by Joe. I won't even try to add anything to it.
    Anyway, nice that you were able to post the codes so we can better "armchair diagnose things.
    Best of luck, you have a challenging decision to make.
  6. Beachbummm
    1,160
    393
    I never balanced my battery cells after the rebuild and that was 20,000 miles ago...just made sure the replacement cell was at 7.4 volts when installed...as far as a place to work on it rent a storage shed for the month for $70 bucks...its a 3 hour job after you get the cell's order 2 and resell the extra one if you don't need it...
  7. GreenCleaner
    28
    Chicagoland
    Thanks for the advice guys. I actually spoke to Joe over the phone for a good hour and he was really helpful and informative! More than all of the Toyota dealerships I've been to over the years. I'm going to buy a battery from 1 of the companies close by and post an update later. Thanks.
    Hi Eric, I actually called you several times over the past 3 weeks and no one ever answers. Even called this past Tuesday. Seemed a little sketchy to me so I didn't bother emailing. But thanks for the offer.
  8. usnavystgc
    3,159
    990
    Tucson, AZ
    Hey GreenCleaner,
    I'm not sure what the problem is with Eric not answering but, I can tell you that he has a great and helpful reputation on here.
  9. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    That's odd. Just got new phone service and had problems dialing out. But I have received plenty of calls inbound. I'll have to have it checked our. Thanks for the feedback.
    You are on the right path. Keep us updated.
    XT1049 ?
  10. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    Regarding the P0420 catalytic converter.
    As long as you are not in California you can use this aftermarket cat:
    Magnaflow 99205HM Weld on High Flow Catalytic Converter Round 2 25" in Out OBDII | eBay
    I have used about 10 of these over the last 2 years and haven't had a problem.
    Find a place ahead of time that will weld it on for you. Try small local muffler shops. The cost of this part is $89, you will pay $50-$75 to have it welded on and can scrap the old cat for $25-$50 on craigslist. (there are precious metals in catalytic converters and there is a high scrap value). If you don't have emission testing where you live and don't mind looking at the CEL then let it go. I would invest in a cheap code reader so you know if you have any other codes.
  11. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    I spoke to her on the phone the other day. She is in a smog test area, so that is not an option.
