2004 Prius Alternator ?
Discussion in 'Gen 2 Prius Technical Discussion' started by dakao, Jun 11, 2011.
  1. Patrick Wong
    18,210
    6,526
    If you are able to drive the car, then it is READY. Look for a dashboard light which says READY. This will be located near the shift indicator and the fuel gauge.
    The DC/DC converter is located within the inverter, which is the large component in the engine compartment near the driver's fender, with the shiny aluminum cover. It sounds like the DC/DC converter has failed which means the inverter must be replaced. I would encourage you to have that done immediately as the car will shutdown and you will be stranded when the 12V battery loses sufficient charge.
    The inverter is covered by the 8 year/100K mile hybrid system warranty. How many miles on the odometer?
    It would be good for you to charge up the 12V battery overnight, before you drive the car to the local Toyota dealer for assistance. Good luck.
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Your said the battery terminals were nice and tight. Did you also check the ground cable where it bolts to the body?
  3. richard schumacher
    7,686
    1,068
    United States
    While you are at a Toyota dealer having the inverter problem diagnosed and repaired, buy a copy of the 2004 Owner's Manual and read it. It's full of info you need to know.
  4. dakao
    dakao New Member
    16
    texas
    My car has 98050 miles, so hopefully Toyota will take care the problem.
    Thanx
  5. bisco
    52,878
    i hope they do, all the best! let us know how you make out.
  6. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    To add to this (when not stepping on the brake while pushing power), when in Accessory (aka ACC) mode, the light on the power button will be green. When in IG-ON mode, the light will be amber.
    It's all mentioned in section 2-6 of my 06's owner's manual.
  7. bisco
    52,878
    i think it's the ig-on that confuses many of us.
  8. dakao
    dakao New Member
    16
    texas
    I called Toyota dealer this morning and was told that the only thing that has 100000 miles warranty is the hybrid system not the generator that charging the 12V battery.
    They also said they can diagnose the problem for $110..
  9. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    That's BS. The inverter is a hybrid component. If the 12V is not getting charged, it is a fault within the inverter that, according to them, can only be fixed with a new one. In fact, the language in the warranty is explicit: "Inverter with converter"
    Please do understand that your dealer may need to be educated by you with regards to the hybrid warranty. Service advisors generally have no idea, and the techs or service manager might have an inkling but generally need to look it up.
    If the inverter is replaced under warranty, you will not be charged $110. If it is something else, then that $110 might be money well spent, so that you have whatever the issue was resolved and have a driveable car?
  10. dakao
    dakao New Member
    16
    texas
    I agreed those Service advisors ain't worth a damn. I called another dealer in town and the service rep told me that the car does have an alternator, he has no clue.
    Anyway, I will bring my car to the dearler and let them check it out.
    Thanx
  11. GWhizzer
    GWhizzer not so Senior Member
    120
    24
    Winnipeg, Manitoba
    Wow, this is scary coming from the Toyota service rep. How can he not know that the Prius doesn't have a normal generator/alternator to charge the battery?
    Of course, my Toyota dealer has put the wrong kind of oil in my Prius that last 2 times I have taken it in, despite my telling them what to put in (they are batting 0 for 2)...
  12. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Hi dakao. If you want to check one simple thing for yourself then take a look at the inverter coolant reservoir (real easy to locate, pink fluid just above the inverter). With the car in "ready" mode, remove the cap and look straight down into it and you should see the coolant circulating. If not then your inverter coolant pump has failed (common problem) and that may have been the original cause of your problems.
  13. dakao
    dakao New Member
    16
    texas
    Thanks, I will do that this afternoon after work, I'm affraid to drive the car.
  14. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    It's worth a call, now, to Toyota Customer Care just to formally log the issue while you're still under the hybrid warranty. I can't say with certainty that the DC-DC converter is under the hybrid warranty, but it seems like it should be. keep us abreast.
  15. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Yep. Scary indeed. You can put him to page 2-13 of http://www.autoshop101.com/forms/Hybrid02.pdf.
  16. dakao
    dakao New Member
    16
    texas
    I think Toyota had a recall on this pump few months ago and they replaced this pump for free on my car.
  17. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Yep and several people have reported having overheating inverter problems starting soon afterwards due to the job not being done properly. So it's worthwhile checking as it's very easy to do (purely visual). I do it now at each service (oil change) along with other basic inspections like fluid levels and air filter condition.
