2004 Prius Coolant Problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Andrew Smillie, Nov 17, 2019.
  1. Andrew Smillie
    Andrew Smillie Junior Member
    17
    Dallas, TX
    I have a strange problem with my 2004 Prius. It has 230,000 miles on it and its been a stalwart ever since I bought it. For the last few years its been the kid car, taking my kids everywhere. Its on its second hybrid battery. Here is my problem:
    The coolant is leaking out somewhere and I can't figure out where. I got home from a weekend trip (not driving it) and there was coolant all over the driveway where it was parked. I took it to my mechanic and he couldn't find the leak so he gave it back to me. I can't find it either. I let the car idle one day for over 1 hour and it didn't leak at all. But its usually parked on the street and there are stains of what I think to be coolant puddles everywhere (and not small ones). There is always a tiny amount on the undercarriage but I can't see any leak.
    My mechanic thinks its leaking into the engine and that could be but I don't know why I am seeing coolant puddle stains everywhere where its parked and then there was the first one I saw before I took it to my mechanic.
    The leak seems to be coming from the passenger side. The puddles are on that side and there is a tiny bit of coolant on that side of the under carriage.
    Any thoughts?
  2. Greenteapri
    Greenteapri Active Member
    330
    388
    Cypress
    Welcome!
    Chances are you have a coolant leak. From where, it's hard to tell from the pics.
  3. Andrew Smillie
    17
    Dallas, TX
    I am not sure what I would take pictures of. I can't find the leak.
  4. Greenteapri
    330
    388
    Cypress
    Time to get your hands dirty or pony up some cash to have someone else look. I'm not sure what tools you have or your level of comfort is working on cars.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    The engine coolant pump is located on the passenger side, front bottom area. Belt driven. Use a flashlight to look at the inside of the pulley (where the pulley is hollow). This is probably the most common source of a coolant leak. The seal on the water pump wears out. Many times the first thing to be noticed will be pink crystals on the inside of the pulley (from seepage drying up). If the inside of the pulley is damp, I would guess you found your leak.
    Every time I work on a Gen 2 now, I use a flashlight to point out that pulley area to the owner. Just so they know what to look for. 50% of the time, there's some pink crystals there. Not enough to warrant a water pump change, but it warrants keeping an eye on. I just let them know they should eyeball it when they check their oil or open the hood for something. Once it becomes damp, then I consider it time to replace the pump.
    See the arrow in the below photo.
    #5 TMR-JWAP, Nov 18, 2019
    SFO and Skibob like this.
  6. PriusCamper
    PriusCamper Senior Member
    13,417
    5,416
    Pacific Northwest, USA
    Great opportunity to deep clean your engine compartment... You might find the leak while scrubbing every nook and cranny. And if you don't find the leak, the clean engine will make it easier to find once it gets worse.
  7. Andrew Smillie
    17
    Dallas, TX
    I took it in and the dealer found the thermostat housing cracked and the gasket shot. Not sure if it's "the" leak but it's a leak. Thanks all for the replies.
    SFO, TMR-JWAP and Greenteapri like this.
  8. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    That would do it. Hope that fixes it. It's good when it's an easy fix.
