2004 Prius Heater Blower Fan Issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ChuckH2004, Jan 9, 2021.
  1. ChuckH2004
    ChuckH2004 New Member
    Oregon
    My 04 Prius blower fan quit working. Took it out and jumped it to a battery and it would not move until I gave it some help. No worries, ordered a new one and plugged it into the harness. It will not spin even wirh help. Pulled the plug on the harness and checked voltage and I get around 13.5V at the harness plug. I get 13.5V in the range from low to high so I figured it would work.
    Fan still will not spin so I am confused as to why when I get 13.5V at the harness in the car and if I disconnect the pigtail from the fan and plug it in I still get the same voltage through the pigtail. Thought maybe the pigtail was bad.
    Just not sure what to think.
    Ideas?
  2. ammdb
    ammdb Active Member
    288
    119
    Indianapolis
    Sounds like your new fan has a bad connection. Use and ohm meter and check the resistance of the motor connector. Should be a very small value.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Don't forget, a blower fan isn't merely controlled by an on-off switch. There's a controller in the circuit. I would say the blower motor resistor/controller fails 10x more often than the fan. Maybe that needs a bit of investigation.
  4. ChuckH2004
    Oregon
    Checked that and it is good to go. Thanks for the help.
  5. ChuckH2004
    Oregon
    Thanks for the tip. I have one on order should be here Monday.
    Going to run a 12V connection from the power supply (cigarette lighter) to a homemade pigtail to run the fan untul then. Will only run on high but at least it will clear my windshield.
    Appreciate the response. I will let you all know if the resistor/controller did the trick.
  6. ChuckH2004
    Oregon
    Replaced the fan resistor/controller and it fixed the issue. Also I did end up replacing the blower motor the old one would work but so noisy it was not worth the aggravation of leaving it in there.
