2004 Prius Help!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by darkgiant, Aug 16, 2015.
  1. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    The door entry, and engine start are two different systems within the fob. The door entry is a transmit and receive system "using the fob battery" as a power source along with a rolling code system. The same code not used twice.
    The engine start system uses a transponder in the fob that returns a fixed code when interrogated and powered by the car it's self.
    John;
  2. darkgiant
    darkgiant Member
    287
    42
    Seattle
    So I got the VCI cable and I installed Techstream. Here is my issue: This car is the SKS model (and it reports that two fobs have already been programmed to the car), but when I register a new key, it tells me to press the lock button from one of the keys. One of my issues that I mentioned above is that the one key I have only lets me turn the car on and off when I insert it into the slot, otherwise it doesn't even lock or unlock, the other key is practically useless, but both keys were built for the car. Any idea here? When I delete the keys, it asks for some passcode, which links me to some Toyota dealer page. Appreciate any help I can get here.
  3. darkgiant
    darkgiant Member
    287
    42
    Seattle
