2004 Prius intermittent starting issues over two years
Discussion in 'Newbie Forum' started by jamielynnsky, Mar 22, 2016.
  1. jamielynnsky
    jamielynnsky New Member
    NY
    I have starting issues that are getting more frequent; it "half-starts", the display lights up but no "READY" light and you can't engage the gears. The start button lights up orange. It never happens during the winter. It does happen during the summer, sometimes hot weather sometimes humid weather, but no clear consistent factors. I use my car all day long and start it like 10 times a day. This problem is getting worse in that it's taking longer before I can start it after turning it on and off several times in a row. It always eventually starts. I bought the car used around 6 years ago and have never changed the 12v battery. I hope to get some opinions about possible causes! Thanks!
    #1 jamielynnsky, Mar 22, 2016
    Jon Senum and ozmatt like this.
    52,761
    welcome! how old is the 12 volt battery?
    #2 bisco, Mar 22, 2016
  3. jamielynnsky
    NY
    I bought it used about 6 years ago or so and I've never changed it.
    kenoarto likes this.
  4. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    get that battery replaced! then report back.
  5. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    hi and welcome, try the 12v first but it may end up being the brake pedal switch.
    does your car have cruise control and if so does it work
  6. jamielynnsky
    NY
    Hi thanks, yes it has cruise control and the last time I used it it worked but I almost never use it.
  7. ozmatt
    637
    263
    Australia
    hi.. Just thought I would mention it, my car has a bad brake pedal switch which causes intermittent "ready" and the cruise control plays up..
