2004 Prius.... Is this a good buy???
Discussion in 'Gen 2 Prius Main Forum' started by Dino33ca, Apr 14, 2013.
  1. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    Hi guys, I'm still considering purchasing a newer car, mostly for delivery, and general transportation. Something reliable, good on gas, and low maintenance costs. I've got it narrowed down to either a Prius, Echo, or Corolla....
    I've come across an '04 Prius with low mileage, all records, and in very good shape with the one exception, wait for it.... It's in need of a new hybrid battery! It would cost me about six k$. The local Toyota dealership gave the owner a quote of about five grand to put a new battery in. (this is in Canada). So, hears what I'm thinking.... I buy a used battery from the States have them ship it for free to a border town where I can drive across the border and pick it up, then put the battery in myself and save about five hundred bucks labor. I found a used one on Ebay for about $850 with 33k miles on it. I'm wondering will any '04-'09 battery pack do or do I have to look for a certain serial number? Does it make a difference if I put a battery from an American car onto a Canadian market Prius? Is this too difficult for a non-mechanical individual to swap batteries?
    I'm also thinking there might be a sliver of a chance that all it needs is a new 12v battery put in. The local dealership said it needed a new hybrid battery but they were somewhat stumped by the car, as they said they've only seen a couple of Prii that have ever needed a new hybrid battery, and that they only had one or two tech's that specialized in hybrids. Maybe they missed a 12 v battery diagnoses? If I buy the car the first thing I'd do is change the 12 v battery and reset all the codes. The dealer said that used batteries were nearly impossible to get a hold of because so many taxi companies buy them up before the dealers can get a hold of any. I asked the service tech if I could still drive the car and they said the computer might limit the speed to 30 km/hour and that it might die on me, so I can't drive it to the States I guess.
    One more question how common is a major repair bill to occur such as a brake accentuator or a computer. I've heard these are quite expensive to fix.
    Thanks in advance for your help!
  2. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    It is not hard, but it is not idiot proof. Remember this is high voltage DC. All 2004-2009 batteries are the same. 2003 and lower are different. 2010 and up are different. Canadian, US, and all other models use the same battery.
    Possible. Dealers are known to misdiagnose these things when the aux bat is low. But plan for the worst.
    If the battery is dying, then it will throw codes. If you clear the codes and drive it gingerly it should be fine for many thousands of miles after first signally death. If the previous owner already used those safety miles, then it will not work very well.
    These things are extremely reliable like tanks. However, always plan for the worst. On any modern vehicle ECUs will cost a few hundred dollars. eBay hunting will save you a ton. There are rare failures of various components but if you are one of the lucky chosen ones, a 4 digit repair bill may be in your future. However, this is true of almost any car. If you buy something else and the transmission goes out, thats also $2K if you take it to a dealership. Used cars are gambles like that, but the Prius is a pretty good gamble if it was taken care of.
    Dino33ca likes this.
  3. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    Thanks Toaster... The service counter lady told me that I'd have to check the serial number on a used battery to make sure it would work in a specific battery swap. They probably didn't know what they were talking about. I just had to make sure. I wouldn't want to buy a used hybrid battery only to find out it wouldn't work in this specific Prius....
    52,803
    how many miles on her?
  5. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    140 000 kms, or 87 000 miles...
  6. bisco
    52,803
    that's pretty low for an 04, hopefully there is nothing wrong with the battery. and if there is, you might consider repairing it yourself, you seem to know your way around these things.:)
  7. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    So, I ended up taking the plunge! I bought it for 6k. It has most options for an '04 except the navigation. Brand new tires (Hero 668, probably a cheep brand?). It's grayish green in color. No accidents. The Toyota dealership said there's nothing wrong with it except it needs the hybrid battery. I drove it off the lot today and am very impressed with it. It's fun to drive and am looking forward to getting more acquainted with her. The Smart key is awesome.
    I took it out today on a temporary insurance permit assuming it wasn't going to run properly because it needed a traction battery. To my surprise it ran great. No warning lights, no problems at all. I drove it for over a hundred miles and it responded perfectly. On the highway I consistently got between five and seven bars on the battery display. I drove up toward a local ski hill, driving for nearly fifteen minutes at a fairly steep incline of over a thousand feet. I did this twice. The fist time the battery never went below four bars. On the way down near the end it had a completely full battery display. The second time I made this run I had the ac on max, fog lights, and radio going. It hit three bars three or four times but only briefly for about a minute. On the way down, again a full battery display.
    I don't know what to think. I'm going to swap insurance over and drive it and see what happens. It wouldn't make any sense to put a battery in it right away. It's a mystery. Maybe the dealership made a misdiagnosis? One other thing, the dealership put a brand new 12v battery in it a few months ago. I tested it by holding the display button and turning the lights on and off three times, it seems good.
    Thanks to all the posters on this forum who have contributed. I made my purchase based on customers reviews and much of the info I got here....
  8. bisco
    52,803
    all the best!(y)
  9. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Even if you do have to put in a traction battery, you will still have a good car after that. There are quite a few Prius running around on this board that have well over 200K on the clock. Good luck to you.
  10. usnavystgc
    3,159
    990
    Tucson, AZ
    If you're not getting any DTC's, don't do anything. Your traction battery appears to be behaving normally. Don't fix it if it ain't broke (as we say in KY).
  11. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Traction battery sounds good. Maybe just give the rear battery fan a preemptive clean up before summer.
