2004 Prius iTech - Battery when car unused for 4 weeks?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MarkinMelbourne, Oct 12, 2017.
  1. MarkinMelbourne
    MarkinMelbourne New Member
    Melbourne
    i-Tech
    We're heading away for a few weeks (4), and wondered if anyone has experience of leaving a Prius unused?|
    Someone suggested take the clip off the negative pole of the small battery - but then you cant get in and out of the car (locking), and will lose some computer memory data one supposes.
    One person said - no problem.
    Appreciate relevant feedback and suggestions. Thanks
    52,804
    welcome!
    you can put a smart charger on the charge point under the hood. there's also an sks shut off switch under the steering wheel, if you have sks. another concern is the hybrid battery. as they age, they dislike not being used. 4 weeks probably isn't a big deal though.
  3. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Use the key in the fob push the clip on the remote. Then pop the hood and open fuse box under the hood.
    There a red cover charge +it there- to bare Metal
  4. MarkinMelbourne
    Melbourne
    i-Tech
    Thanks for that. The car will be at the airport. is smart charger something you can leave safely under the hood? does it need AC power connection?
  5. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    You can either do it at the terminal in the fuse Box or plug one into the cigarette lighter
    Or unbolt the red wire from the fuse box it like unbolting the ground
    But easier to get to
    I Use a piece of plastic to hold it up off the bold Not sure how long that wire is
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    4 weeks is pretty risky. I have a 2007 prius that I bought about 3-4 months ago. I don't use it, as I bought it merely because it was a fully loaded model and the price was impossible to pass up. I installed a brand new battery in it, and leave the smart key system turned on. I've had to recharge the battery twice due to it dying.
    If you have a full size battery and jumper cables, or a jump pack, just put it in the car and use it when you get back if needed. or, you can get crazy and connect the full size battery to the prius battery before you leave, so you have the equivalent of 3 prius batteries connected to the car. That would last months.
    #6 TMR-JWAP, Oct 12, 2017
  7. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Why not just turn off the SKS button under the steering wheel to minimize unnecessary 12V drain?
    Why not just disconnect the 12v GROUND?
    Why not just put smart battery charger that is AGM compatible?
  8. bisco
    52,804
    he's at the airport, so charging is out of the question.
    if you disconnect the 12v neg, how do you open the hatch?
  9. bisco
    52,804
    in that case, i think turning the sks off and a jump pack would be your best bet. or they may have free jump service at the airport? but you would have to wait for them, and make sure they don't cross polarize the connections.
    the big question is the health of the 12v to begin with. i leave mine every winter for 5-6 weeks without problem, but i know it's a healthy battery.
