[2004 prius] I've lost all of keys
Discussion in 'Gen 2 Prius Accessories & Modifications' started by joshua jung, Jan 21, 2016.
  1. joshua jung
    joshua jung New Member
    templestowe
    I
    I'm 2004 prius owner. Recently I lost all of keys. I have no any keys.
    So I contacted a Toyota dealer who said it costs $2400 including 2 keys & programming.
    Another Toyota dealer told me it will cost more than $4000.
    I've been hesitating....
    Which one much better between selling my car and fixing the car.....
    If I repair my car, what's the best way?
    Please give me better advance.
    In advance I appreciate it.
    Thanks
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
  3. 48mpg
    48mpg Member
    193
    47
    florida
    I
    if you are in America join triple A plus, I think its $125..
    wait a week then call and tell them you lost the ONLY key fob and they will send a locksmith out with a new one free...
    it used to work but you can only do it once..
    then order a used one off e bay for $40 and follow the steps to reprogram it.
    even if they want to charge you something its cheaper then the dealer and you will have a year of road service and towing
    good luck
    Elder C. likes this.
  4. dorunron
    3,318
    1,105
    Houston, TX
    48mpg, I think the OP is from down under - Australia
    Google Maps
  5. 48mpg
    48mpg Member
    193
    47
    florida
    I
    maybe they have a similar service down there, just tossing out an idea for them
    dorunron likes this.
  6. Lance DiBitetto
    Lance DiBitetto Junior Member
    23
    ocala, Fl
    where do you live, In Tampa there is a place called tampa hybrids that will setup a new key for you for 150.00 including the fob. if they can charge that little, I'm sure that there are places out there that can do it for a better price.
  7. 48mpg
    48mpg Member
    193
    47
    florida
    I
    that's to copy an existing fob ...they have to reprogram the car at the dealer when all fobs are lost
  8. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I'm sure that Steve at Prius hybrids sales and service Scottsburg Indiana can supply a pair of fobs and the ECU that they are paired with at a reasonable price. Ask a local Prius repair facility how much to install the replacement ECU. If you were able to get to southern Indiana, Steve would get you going at a low cost.
    JeffD
  9. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Joshua,
    A 2004 Prius, the reset can be done via software.
    A new ECU is not needed!
    Your Prius can be reset via Techstream with a seed code if all keys are lost.
    You do not need to replace any hardware.
    Graeme1949 likes this.
  10. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Here is the screen in Techstream.
    It says...
    Smart Code Reset:
    Use this function to erase all Smart Codes in case of losing all keys.
    You could fly me down to Florida, we could go to dinner and a show, I could bring new keys and program your Prius, all for about $2,000 less than what the dealer is quoting.
  11. 48mpg
    48mpg Member
    193
    47
    florida
    I
    I have the techstream from Amazon. the $25 special, will this version still reseed the key fob without any special codes or I.D numbers? my car's SKS and black door buttons are not working and the original fob was destroyed so I have the basic functions with a fob from e bay..I have wanted to try the reseeding but don't want to erase the one working fob making the car inoperable .
  12. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Your question...
    Will Techstream reseed the key fob without any special codes or I.D numbers
    The answer is, "No".
    Techstream is able to generate a 96 digit Seed Number (challenge), but in order to complete the process you would need to enter an appropriate Pass Code Number (response) based on the Seed Number.
    Techstream cannot generate the Pass Code Number on its own.
    You need an outside source/service/program to generate that Pass Code Number.
    Example of Seed Number (challenge):
    2434720b07120da077acc87353dc16d5f4bb45d16c6d4ead5b2ac87abbeb668be07fb9198a8fc366988c841054666b66​
    Example of the Pass Code Number (response):
    647852​
    (This is just an example. This set of numbers will not work for you.)
    #12 ericbecky, Feb 19, 2016
  13. 48mpg
    48mpg Member
    193
    47
    florida
    I
    THANKS! this is what I thought and is why I never tried it ...Id be dead in the water if I erased the only working fob
  14. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    If you have techstream and want to proceed with it, let me know.
    I have codes available and can work with you.
  15. 48mpg
    48mpg Member
    193
    47
    florida
    I
    thanks, im not sure what the problem is since the black door buttons are also dead..i will keep you in mind if I can get that problem fixed, the door buttons should work without the sks working ...shouldn't it?
  16. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Not quite sure what you mean by door buttons.
    Two things
    1) fob starts car
    2) fob unlocks doors (using fob buttons or sks functionality)
    Obviously you have 1.
    You will not be able to use the fob to lock or unlock the car via buttons or via sks if it has not been programmed.
  17. 48mpg
    48mpg Member
    193
    47
    florida
    I
    the black locking buttons on the outside door handles and hatchback don't work, fob must be inserted into the dash for the car to start,metal key must be used to lock and unlock the doors from the outside..valet button under steering wheel has no effect, same problem in both positions...maybe theres a bad connection somewhere
  18. jjmerp
    jjmerp Junior Member
    51
    22
    Ohio
    Does the red light come on when the FOB buttons are pressed? Button could be stuck and battery could be dead.
  19. 48mpg
    48mpg Member
    193
    47
    florida
    I
    yes the light comes on, buttons click, new battery in fobs..thanks
  20. M.Aqrbawi
    M.Aqrbawi Junior Member
    Jordan
    Dear ericbecky,
    Can you please provide me with passcode for my car (prius 2013) ?, if yes i will send to you seed number.
    Thanks ☺
