2004 Prius key issues
Discussion in 'Gen 2 Prius Technical Discussion' started by NinaF, Oct 15, 2018.
  1. NinaF
    NinaF Junior Member
    Martin, TN
    I've read through several threads, but couldn't find an answer to my problem.
    Here are the details:
    My key stopped opening/locking doors (both when in pocket or pressing the key buttons), but still started the car when inside the slot. Changed the battery in the key, it still didn't open/lock doors, but still starts the car when inside slot. It doesn't start the car when not in slot.
    Got the second key (with brand new battery) to open and lock the car when I pressed the key buttons. It doesn't recognize the key when it is in my pocket. Again, car only starts with second key in the slot.
    I have checked the button under the dashboard and it is in the correct position. 12 v battery was changed in July 2016. The light for "maintenance required" appears when I start the car. Next oil change 1K miles away (99586). Maybe something else needs to be checked? In 14 years, I've only seen that light go on for oil change.
    This car was bought new in 2004 and has 98299 miles in it. I love my car and was hoping to drive it to the ground.
    Any ideas on what can be the problem? I thank you all in advance for any help I can get.
    #1 NinaF, Oct 15, 2018
    52,804
    you can't judge the 12v by age, it needs to be tested. is the sks button under the steering wheel on?
    maintenance required is an alert and it just means it has been 5,000 miles since it was last reset, and doesn't refer to anything wrong.
    NinaF likes this.
  3. NinaF
    NinaF Junior Member
    Martin, TN
    Yes, the button is on. I checked after I read the threads.
    52,804
    stop by an auto parts store and ask for a free load test
    NinaF likes this.
  5. NinaF
    NinaF Junior Member
    Martin, TN
    Will do. Hopefully that is the problem. Thanks so much! Will post here when I find out.
  6. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Rubber membrane could be jamming several keys down. New case might be in order.
    NinaF likes this.
  7. NinaF
    NinaF Junior Member
    Martin, TN
    An update:
    Had the 12 v battery checked and it is fine.
    Had an oil change and one of the keys started working normally again (car recognizes the key). Could the oil change have had anything to do with the malfunction of the keys? The other key (new battery) still doesn't work as far as opening/locking doors go, but turns the car on when in the slot.
    I'll take the car on Thursday to have it plugged into a computer. Maybe there is something else going on.
  8. bisco
    52,804
    no and yes
  9. NinaF
    NinaF Junior Member
    Martin, TN
    I guess the "yes" part has to do with the "maintenance required" light and the whatever button/code/witchcraft that made it disappear after the oil change?
    And the "no" part with the relation between oil and key?
  10. bisco
    52,804
    yes, there is something else going on. check the 12v connections for tightens and cleanliness, especially the negative to ground
    NinaF likes this.
