2004 prius new batterys but, wont run
Discussion in 'Gen 2 Prius Main Forum' started by jordan85, May 30, 2018.
  1. jordan85
    jordan85 New Member
    central city
    I have a 2004 prius, i installed a new doorman hybrid battery and a new 12v battery but now have the triangle of death and will not start. I have checked all fuses and relays and it has a car emblem with a ! mark in it and also a battery image that says main on it. What can i do to fix this it ran before i installed the new batterys.
  2. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    Presumably, tackling a job of this nature, you have a Prius capable code reader? What codes are you getting?
    • Are you aware you need to push the power button twice after disconnect either of the batteries to get the car to start?
    • Did you clear any codes before attempting to start?
    • Have you ensured the safety interlock is correctly installed, particularly step 3?
    Raytheeagle likes this.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Just a quick correction. A Dorman battery is not new. It is full of USED cells. With a 12 month warranty.
    The picture dolj attached is a good one.
    It is a common mistake people make.
    Also, as part of the Dorman install you are REQUIRED to clean the hybrid fan. Can you confirm that you plugged back in the fan connectors?
    Now that you have a used battery in your car you may want to purchase some diagnostic tools so you can keep an eye on hybrid battery data etc. Block voltage, battery temp, etc
    Cost you less than$75
    Android phone/tablet
    Elm 327 Bluetooth OBDII reader
    Torque Pro app
    You can use the tools to also read and clear error codes.
    #3 ericbecky, May 31, 2018
