2004 prius PS warning light
Discussion in 'Gen 2 Prius Technical Discussion' started by mmmadog, May 1, 2020.
  1. mmmadog
    mmmadog Junior Member
    16
    Evergreen state
    Went to leave in the car and the read triangle of death greeted me and main screen said PS. No warning previous to this but now have no power steering and checked for codes with ODBlink and nothing. This is a hydraulic power steering system?? Checked all fluids and everything looks fine. Do I need a new pump??. Car does have over 220k. any help much appreciated.
    52,873
    electric. you need tech stream diagnostic software from amazon, and a windows laptop
  3. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    Or Torque Pro if you have an android device and your dongle is compatible with Torque Pro. You need the Pro version if you want to interrogate all the Prius ECUs, like the power steering ECU. There is a code in there, your current solution just can't see it.
  4. mmmadog
    16
    Evergreen state
    I would think the OBDlink would bring up a simple code other wise it's junk. Did watch youtube video and one guy tapped on the power steering control module and it worked again. I tried it and what do you know it's working again.Going to get a spare from the junkyard just in case. Thanks again.........................Matthew
  5. bisco
    52,873
    maybe corrosion or a bad solder joint
    unfortunately, because of priuses 9 computers, most readers are totally confluxed
  6. dolj
    dolj Senior Member
    8,652
    4,403
    It depends on what you base your assumption and how you define a simple code.
    The most basic of code readers will only interrogate the ECM, some others add the SRS ECU (airbag system) and/or ABS ECU.
    The reader you want is one that reads all of the Prius' ECUs and interprets the data correctly.
    If it does what it says on the box it will do, then it is not junk. If you are trying to something that is outside of these functions, it doesn't make it junk, it just makes it useless.
  7. Desiree Vigil
    Desiree Vigil Junior Member
    Pacifica
    If I buy one off amazon can it tell me why my car (05 Prius ) won’t turn off sometimes ? Also the cluster lights don’t work sometimes as well (no speedometer)!
  8. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Geeze, the Prius does not have a PS pump, nor fluid! It was one of the first mass-market vehicles to use "EPS" or Electric Power Steering.
  9. dolj
    dolj Senior Member
    8,652
    4,403
    You likely have a failed combination meter. These threads are a good starting point:
    combination meter repair - DIY
    T-SB-0172-09 Combination Meter - Intermittent Display
    In both threads read the first one or two pages then skip forward to the last two or three pages.
    Matt @Texas Hybrid Batteries does an exchange service for refurbished units good price, lifetime warranty, and ODO configured to your current mileage. Click the link and then click Start a Conversation to make contact.
