2004 Prius - Transmission replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by Danno Harrington, Jun 13, 2023.
  1. Danno Harrington
    Danno Harrington Junior Member
    Seattle, Washington
    I have a 2004 Prius with only 136,000 miles and have been advised by my trusted technician that it will cost me north of $5,000 to repair/replace. I see reconditioned / used transmissions for $500-$600 online with warranties. Why is every shop I ask quoting me $5000+? Am I missing something?
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Welcome to PriusChat!!
    What obd2 code did you retrieve that pointed you in the direction of a transmission replacement?
    FYI : you're moderated until you've posted 5 times.
  3. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,520
    Durham NC
    So just buy you a transmission from a Gen 2 car that was running that was just put out of service they're all over the place depending upon where you are I have two here and then take it to somebody who changes out transmissions it should cost about $200 to get it swapped out It's not that big of a job actually they practically fall out of these things
    52,878
    It’s a big job, and mechanics are too busy and would prefer you went somewhere else, so they throw out a big number to hopefully scare you off
