2004 Prius VSC, ABS, (!) and emergency brake light on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by robl45, Dec 5, 2016.
  1. robl45
    robl45 Member
    137
    Hello,
    When driving to work today, the VSC, ABS, (!) and emergency brake light came on and stayed on. I read through here quickly and did the diagnostic test on the screen and the battery appears to be okay. dropped to about 11.8 under load, charging is 14.0-14.2. I checked the fluid reservoir and I took off the cap and see bubbles while it is running. Car still seems to be braking okay. The brake relay thing does run every few seconds that I can hear under the front dash. The car seems to brake fine and I really don't use the brakes much, really just braking from the electric motor. Is there anything else to check?
    52,889
    the best thing would be to have the codes read, or buy a mini vci for diy? also better to check the battery directly with a volt meter.
  3. robl45
    robl45 Member
    137
    I don't have a code reader but I will try the paper clip thing to get the codes if I can manage to find how to do it again. If anyone can post here how to do it so I can find it easily later, that would be great.
  4. JC91006
    16,939
    8,647
    There's probably a problem with your hv battery. You should get the codes read.
    The 12v battery at 11.8v is low, but shouldn't be the problem here
  5. robl45
    robl45 Member
    137
    ! I got 5-7. Abs. 4-2. Vsc. 4-5
  6. bisco
    52,889
    what is that?
  7. robl45
    robl45 Member
    137
    The blink codes from jumpering the obd port.
  8. bisco
    52,889
    oh, i see. i don't know how to decipher those, have you tried google?
  9. robl45
    robl45 Member
    137
    Yes, I googled, did not really find anything on the codes. I checked twice to make sure I wrote them correctly.
  10. bisco
    52,889
    the regular codes come up on google. maybe you can subscribe to toyoatechinfo for the descriptions, or look through the technical forum.
  11. robl45
    robl45 Member
    137
    So I reset it with the paperclip trick and it was fine, until I just slightly tapped the emergency brake. I was driving and decided to make sure I could hit it in case the brakes really have a problem. I barely touched it and the lights came back on. I cleared the lights again when I got home. This started after I upped the tire pressure yesterday from around 30psi that they were on to 35psi. I made no other changes and have been driving this 100 miles a day during the week for a over a month already. Could this cause it?
  12. bisco
    52,889
    not that i know of, could your e brake be sticking?
  13. robl45
    robl45 Member
    137
    I don't think so, I hit the ebrake when I got home and then released it. Could increasing the pressure cause this? Only thing I changed.
  14. bisco
    52,889
    i increase my pressure all the time, never had any lights come on. maybe jack her up and see if all the wheels spin freely, or go for a long ride and see if one feels hotter than the others.
  15. robl45
    robl45 Member
    137
    Could this really be an issue since I drive 100 miles a day and my gas mileage is 49mpg? I'd assume I'd notice a drastic decrease.
  16. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    I had exactly these warning lights. It happened intermittently for a while.
    It turned out to be traction battery EDIT (terminal not technical) terminal corrosion due to rain leaking into the car from a faulty hatchback door seal.
    #16 GT4Prius, Dec 6, 2016
  17. robl45
    robl45 Member
    137
    Lights came back After 40miles. Anyone have any ideas on the codes?
  18. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    Did you see my suggestion?
    After corrosion was repaired car has been fine now for two years.
  19. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    I don't know how accurate these are, but here's what I found.
    ELECTRONICALLY CONTROLLED BRAKE SYSTEM
    NOTICE:
    When replacing the brake booster with master cylinder (skid control ECU), sensor, etc., make sure that the power switch is turned off, the stop light switch is off, and 2 minutes have elapsed since the driver's door was closed.
    HINT:
    •  If no abnormality is found when inspecting parts, inspect the skid control ECU and ground points for poor connections.
    •  When 2 or more DTCs are detected, perform circuit inspections one by one until the problem is identified.
    •  Inspect the fuses and relays before inspecting the trouble areas as shown in the table below.
    ABS 42 Electronically Controlled Brake System Malfunction
    • Electronically controlled brake system
    VSC 45 Electronically Controlled Brake System Malfunction
    57 (C1257) Power Supply Drive Circuit. Inf Codes 361, 362. Brake booster with master cylinder (Skid control ECU)
  20. robl45
    robl45 Member
    137
    Thank you very much, could someone translate this into english for me. I'm not sure exactly what I would be looking at. Is this something I can troubleshoot myself?
