2004 Prius with mouse chewed wiring harness. HELP
Discussion in 'Gen 2 Prius Technical Discussion' started by monoshock, Oct 3, 2017.
  1. monoshock
    monoshock Member
    66
    27
    Rocky Top TN
    Hello
    I have found a 2004 Prius for sell. The owner says he took it to a garage and it has the shielded wiring chewed and won't go in drive or reverse. Where is the sheilded wiring? Is it inside the cabin or under the hood? I'm thinking about buying it. I have a 2005 now.
    Help
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    I would not buy that car in fact I would run....they have only discovered the tip of the iceberg.
    Your probably thinking you can snag it cheap and with a little work be ok but the prius is the absolutely worst car to own if it has electronic gremlins. Even all these years later most dealers from the story's I hear here are still not experts in troubleshooting and rely on shot gunning parts to figure out which one is bad etc...
    My point is you will have very few resources to ride in and help except maybe the dealer at a $140 an hour fishing expedition.
    #2 edthefox5, Oct 3, 2017
    SFO likes this.
  3. greasemonkey007
    greasemonkey007 Active Member
    287
    107
    South Central Arkansas
    It may be worth checking the orange safety plug on the hybrid battery to make sure that it's latched properly. When inserted, you fold the handle up 90 degrees and then push straight down to close a safety switch. If it's not pushed down, you're not going anywhere either.
    I'd also ask where the mechanic found the wiring chewed.
  4. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    What do you mean by "shielded" wiring? Your definition of that word, would help in the diagnosis.
    Dxta
  5. edthefox5
    10,096
    4,840
    Clearwater, Florida
    There's shielded wire everywhere in this car.
  6. Beachbummm
    Beachbummm Senior Member
    1,160
    393
    offer $100 for the car, its 14 years old and will be a money pit no matter how much you have to do to get it moving again... odds are you will need to replace the entire harness to make it right
    edthefox5 likes this.
  7. bisco
    52,891
    most likely the main wiring harness, which is a $7,000. repair.
  8. greasemonkey007
    287
    107
    Not if you can find and fix the problem. Depends on how bad you want to find it! I could do a lot of looking for $7000!
  9. bisco
    52,891
    and you're not far from tennessee!(y)
