2004 prius wont start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Michael Balliram, Apr 26, 2020.
  1. Michael Balliram
    Michael Balliram New Member
    Fl
    Ok so i bought a 2004 prius with 82k miles o drove it home used it for a week got every light in the world on i did tons of research checked the 12v battery charged it and used 2 other batteries to see if it would start but didnt a week later i put the fully charged 12v battery in and it started with no issue used it a week and it did it again only when i tried and did the same thing again mdf and the combination cluster is blank except the seat bell sign and car beeps when u open the door like its it but wont drive ive inserted the key and try to start it but a check engine light appears quickly and disappears ive tried everything on youtube even fixed a trunk water leak i i found but not on the battery opposite side ive unplugged harnesse checked ground on battery all fuses etc oil was over filled by toyota but i corrected it im out of ideas now and i dont think its a HV battery issue because the battery didnt discharge after sitting a week when i couldnt start it and when it was started it got charged back up im lost now i have bought a code reader but havent received it yet
  2. Michael Balliram
    Fl
    Sucks cause i have a rsx type s with 500 whp this is suppose to be a work car never had a toyota but this just sucks
  3. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Welcome to PriusChat!!
    You might check and clean up the MAF.
    Time to upgrade the tool arsenal to include a mini-vci cable and a copy of techstream.
    Did you have any DTCs worth sharing?
    JC91006 likes this.
    52,886
    sounds like somethings draining the 12v when it's off. what were you expecting with a 16 year old car?
    with today's gas prices, you might as well drive the rsx
  5. Michael Balliram
    Fl
    I tried 3 diffrent 12v batteries which all were tested and worked wasnt the issue
    I do food delivery i cant do that in a race car and i was thinking my rsx is 18 years old ran hard and never gave me a issue expected the same from the reliable toyota
    Code reader will come in today i will clean the MAF also but can the MAF cause the car to not start attached is a youtube link of the issue but my check engine light comes on for a second and disappear
    #5 Michael Balliram, Apr 29, 2020
  6. Michael Balliram
    Fl
  7. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Best to do an OBD2 for codes (DTCs) and post then here for additional guidance.
    Missed the part about the combination meter being blank - You may need either attempt a DIY fix (replace the capacitors) or order a replacement with a lifetime warranty from Matt at : Prius Speedometer Replacement
    (didn't watch the video)
  8. Michael Balliram
    Fl
    So i found out the check engine light and nothing on the screen was a relay that was wiggling under the hood seems to have reset the ecu i did get the code reader but custom pids arent working for some reason on torque pro and codes havent appeared again yet
