2004 Prius worth replacing front struts?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Toyotally04, Jul 27, 2022.
  1. Toyotally04
    Toyotally04 Member
    130
    17
    SoCal.
    My 2004 Prius reached its 200,000 mile hallmark early last month.
    Its front struts has been janky for quite a while now. It was squeaking earlier this year, but now it's bouncy.
    Back in April, a franchise mechanic shop quoted me $1,300 for complete front strut assembly with "premium option". Front strut assembly with cheaper parts would be $930.
    So you guys think it's worth it, or should I be shopping for a new car?
    TTLLY04
  2. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
  3. Toyotally04
    Toyotally04 Member
    130
    17
    SoCal.
    Oh, labor is 400...
    ===EDIT===
    I'm looking at the quote invoice.
    It looks like front complete strut assembly costs from 250 ("cheap") -450 (prem) ea.
  4. PriusCamper
    PriusCamper Senior Member
    13,412
    5,414
    Pacific Northwest, USA
    Find a friend or family member who works on cars and pay them for the labor... They'll appreciate you hooking them up and you'll save lots of money.
    monoshock likes this.
  5. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    Can you buy a new car for $1,000?
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,110
    2,011
    NJ-USA
  7. Toyotally04
    Toyotally04 Member
    130
    17
    SoCal.
    I guess, if I want to buy a car from the previous century...
    According to some "social influencer" auto mechanics, at this time with all the global craziness going on since beginning of 2020, probably pretty hard to find one that'll function well and last long.
  8. ttou68
    ttou68 Active Member
    351
    211
    If struts is all you need then go ahead find someone reasonable and have the job done..
    $1,300 for 2 front struts is bit ridiculous..
    I would replace both front and rear struts..
    I've done swap out struts for my mother's Prius and it wasn't bad at all...
    FYI, have a alignment done afterwards..
    Toyotally04 likes this.
  9. BiomedO1
    BiomedO1 Senior Member
    4,531
    2,383
    Left Coast
    In today's car market; if that car has been proven to be reliable and in decent shape - shop around and get it repaired. You'll have to pay a premium for a good commuter car now. That's assuming you can find one. If you want to move into a 10-15 mpg SUV, there's plenty of them available.
    Just my 2-cents
    PS - stick with KYB or OEM, cheap struts tend to bottom out and be overtly soft in my experience.
  10. Todd Bonzalez
    Todd Bonzalez Active Member
    250
    160
    Ireland
    Seems awfully expensive, like 3x what the job should cost.
    Get a price from a local independent mechanic. I'd be surprised if it cost than a few hundred.
    You don't need "premium" struts btw
    #10 Todd Bonzalez, Jul 29, 2022
  11. Toyotally04
    Toyotally04 Member
    130
    17
    SoCal.
    @ 200,100+ miles, if I got OEM struts (costing couple hundred extra), do you guys think it'll go a long way (say another 10 years / 80,000 miles), or make no difference with brands like KYB?
  12. alftoy
    1,132
    518
  13. Toyotally04
    Toyotally04 Member
    130
    17
    SoCal.
    So done a bit more (noob) research:
    My Prius doesn't "nose-dive" as exaggerated on YT.
    I checked the top of my front struts, I don't see any liquid oil on my hands. The rear tires don't show visual access to any struts, right?
    Still, on occassion, I'd hear a squishy noise from time to time; and I am aware of the car bounces light a bit more.
  14. Toyotally04
    Toyotally04 Member
    130
    17
    SoCal.
    Um... so I'm not sure whether this is related exactly (I forgot to mention it, I think)... but earlier this year, I mentioned to the franchise mechanic about occasion noise while driving, after his inspection is when he told me about the struts.
    Soooo... the noise, I would describe: like a high-pitched squeaky toy that happens when I'm driving locally at roughly 30 mph.
    Any thoughts?
  15. bisco
    52,789
    not sure how struts could make a constant noise. should only happen over bumps or uneven pavement.
    can you make a recording and post?
  16. Toyotally04
    Toyotally04 Member
    130
    17
    SoCal.
    do not know... maybe i should start another thread with a list of empirical symptoms.
    So the noise is like a toy rubber ducky squeak, if that makes any sense or IYKYK if you're old enough. I could drive 25 miles in one day trip on local streets and I probably hear it sporadically half a dozen times on relatively smooth roads.
    I hear the squeaks from 3 relative areas while driving, all right side: near the front right wheel, from behind me over my right shoulder (as if the rear wheel), and sometimes front right-center of the undercarriage.... (weird I know).
  17. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    You probably just need your suspension lubricated – providing that all the bushings are still ok.
  18. Toyotally04
    Toyotally04 Member
    130
    17
    SoCal.
    How much would a mechanic charge for a job like that?
  19. Another
    1,819
    520
    Naples, Florida
    Lubrication is cheap. But what happens as cars age, the rubber bushings start losing elasticity and begin bulging and/or cracking like the discs in an aging spinal cord. I’d get a lube job first. You don’t want to start piecemeal replacement of suspension parts.
    Are you sure it’s not something simple like a loose bumper or plastic splash shield that’s rubbing?
  20. Toyotally04
    Toyotally04 Member
    130
    17
    SoCal.
    So I dropped my Prius at a Toyota dealership and asked for an oil change.
    When I returned, this is what they recommended:
    My Prius is now @ 200,000+ miles.
