For Sale 2004 Silver Prius Gen II $1000
Discussion in 'Private Sales' started by Ted W., Nov 10, 2019.
  1. Ted W.
    Ted W. Junior Member
    St. Louis
    I'm selling my 2004 Silver Gen. II Prius as a parts car, that is, the engine doesn't run so you'd be buying the entire car either for parts or to try and get it running again. Has 300,000 plus miles. (Odometer stopped working at 300xxx, was a problem with the Gen. II's)
    Was a great running car before engine problem. It's sucking gas into the oil so it will need to be rebuilt. I can't afford that.
    Has a new hybrid battery with the newer designed bus bar, newer 12V battery, new factory stereo, full sized spare and many other newer parts.
    I'm asking $1000. (The hybrid battery alone is worth more than that.)
    Will not ship or tow. Pickup only.
    Aaron Vitolins, dig4dirt and bisco like this.
    52,858
    where did you get the battery?
  3. Ted W.
    St. Louis
    Both batteries came from Toyota. They were installed by a professional shop here in St Louis that only works on Priuses and a few other import cars.
    SFO likes this.
  4. ETC(SS)
    7,557
    I wonder if @Sharnold would be interested in this car?
    Sharnold likes this.
  5. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    GLWS
    Any closer, I would be snatching that deal myself
  6. Sharnold
    Sharnold Active Member
    409
    126
    Alabama
    Ty for the tag I appreciate it. If I was closer I would jump on it. Sounds to me like the pistons are allowing gas to seep through to the crankcase. A misfiring cylinder or cylinders can allow massive seeping of unspent fuel and will eventually thin the oil, faulty fuel pressure regulator, faulty leaking injector......... someone needs this car it could be a quick fix with the same engine.
  7. hydrowindandsolar
    hydrowindandsolar Junior Member
    Missouri
    Did you find a new owner for it?
  8. Ted W.
    St. Louis
    I apologize for not responding sooner.
    Yes, I did. The car has been sold. Someone locally snatched it up off of FB Marketplace literally seconds after I posted it!
  9. Ted W.
    St. Louis
    Update. The Prius has sold.
