2004 Strut replacement question
Discussion in 'Gen 2 Prius Technical Discussion' started by sciencekit, Jan 9, 2012.
  1. sciencekit
    sciencekit Junior Member
    76
    Norfolk, VA
    I am replacing my front and rear struts (195K miles), and so far can only find KYB components. Those are OEM and I suppose they are OK (found them on a Toy Dealership parts site and elsewhere) Any suggestions if I should replace just the struts, or should I anticipate springs, dust covers, mounts, etc.?
    Anyone performed this and learned "Wow. Wish I had also ordered 'x', 'y', and 'z'?" Also is the a better sway bar for the rear?
    Thanks! :)
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The KY Struts have a lifetime warranty and are good quality. I replaced the upper mounts as well when I replaced my 2004 struts.
    JeffD
  3. ranczar
    ranczar Junior Member
    Michigan
    2020 Prius Prime
    I have an '04 and just replaced my struts (all 4) about a month ago. I bought KYB parts and had a mechanic friend perform the work. He made sure I purchased all the parts that might be needed so that he could finish the job without having to order more parts. Along with the 4 struts you'll need 2 front strut mounts, two strut mount bushing kits (one for each rear wheel) and two strut boots, one for each rear wheel. (check the private sale section of this forum, as I have a new pair of these strut boots for sale at a reduced price!) After the install, you'll need an alignment, so be prepared for that expense, too.
  4. Patrick Wong
    18,214
    6,530
    The OP will need the pleated boots for the front struts. The bottom of the coil springs rest on a rubber insulator and it would be reasonable to replace those as well.
  5. sciencekit
    76
    Norfolk, VA
    Tire Rack seems to offer all four struts for a much better price than CT. Anyone know if the KYB GR-2 struts are somehow different than the OEM? Besides being cheaper.
  6. cnschult
    cnschult Active Member
    772
    97
    Michigan
    i don't feel like buying spring compressors and dealing with the dangers of all that potential energy, I'd rather buy complete struts, you spend a little extra but you get all new springs and mounts and boots and install becomes much easier, quicker & safer. Completestruts.com doesn't have the prius yet, anybody know where else I can get a set of complete struts?
  7. Patrick Wong
    18,214
    6,530
    I have posted on how to do this job and it really is easy and simple *if* you have the correct strut compressor tool.
    Nevertheless if you don't wish to do it yourself, then may I suggest that you remove the old strut assemblies, and take those along with the new parts to a friendly local mechanic, asking him to remove the old parts and replace with the new. My guess is that he might charge you $50 or so for that service.
  8. cnschult
    772
    97
    Michigan
    thanks Patrick, but my car sags a little in the back, the struts/shocks push the tires down and the springs hold the car up, right? this is very important for me because I like to run taller tires, especially in the winter to give me more ground clearance. So I thought I would just replace everything all at once. I'm sure there is a video on youtube to show you how to push your car down and see how quickly it takes to pop back up to see if you need new struts or shocks, I'm only at 51K but Michigan roads are murder on suspensions.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Yes if sagging you need new springs also.
    KYB makes an excellent strut. Make sure you get a new bearing assy
    that sits on top of the strut and allows the the strut to spin back & forth.
