1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
2004 Toyota Prius no lights on after 12v battery replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by my_priuss, Dec 21, 2017.
  1. my_priuss
    my_priuss New Member
    26
    Plano, TX
    everyone!
    I'm new to this forum, so bare with me.
    I have 2004 Toyota Prius with smart lock. The car acted weird yesterday. First, I had to open the door manually with the key (Normally, I only have to have the key in my pocket). When I tried to start the car, it won't start but I noticed some of the lights on the dash were on. I don't remember completely which ones. So, I tried to find online if people had the same problem. After reading many articles, most people said the most likely culprit is the 12V battery. I followed a video tutorial on youtube (URL is provided below) on how to do the job and I thought it was an easy thing to do so I decided to do it myself. This morning, I bought the battery (the same exact one from the video) and replaced it with the old one. As far as I can tell, there is no power at all after the new one is installed. I tried to start the car but this time no lights were on. I don't really know what's going on.
    Here is the to the video tutotial on youtube:
    I hope any of you have the same problem with me and know how to fix it.
    Thank you in advance!
  2. WilDavis
    WilDavis Senior Member
    2,488
    2,149
    49
    A couple of years ago, I experienced similar problems with my 2009 Gen II. The SKS system started getting "flakey" and so I replaced the button-cells in the FOBs, but that didn't seem to fix it, so eventually had the dealer do a load test, and sure enough the 12V AuxBattery was dying (well, it was 6+ years old! :eek:). I jumped the car with my trusty Power Pack (see threads passim) - but I had the dealer replace the 12V AuxBattery (the car needed to go in for a service anyway!) - and (just for completeness) here's a test which might be useful to you:
    DO-IT-YOURSELF TEST PROCEDURE (thanks to jdenenberg):
    - Without brake pedal, press the Power button once and release to enter ACC mode
    - Press and hold the MFD Info button, then turn the lights on and off three times to enter Maintenance mode; release Info button
    - Press “Menu” (on screen)
    - Press “Display Check”
    - Press “Vehicle Signal Check” - the battery voltage is shown and should be about 12.4 to 12.8 Volts (normal for an unloaded battery)
    - Again without brake pedal, press Power button and release to put a current load on the battery - the voltage should stay above 12.0V (if less than 12.0V the battery is not well, or there is a fault or unusual load somewhere)
    - Press brake pedal and press Power button once to enter "Ready" mode - the battery is now charging at about 14V (if less than 13.6V or more than 14.4 there may be a problem with the charging circuit)
    - Turn car OFF to leave Maintenance mode
    …and if you see any of the interior lights going dim, that's a sure sign the AuxBat is about to up-and-die! :eek:
    - hope this helps - Wil
    Raytheeagle likes this.
  3. my_priuss
    26
    Plano, TX
    I will give this a try. I will let you know about anything that happens after. Thanks!
  4. Dxta
    Dxta Senior Member
    1,931
    765
    Lagos
    First things first.
    Was the READY light on, when you tried starting the car? If it came on the dash, and didn't start, probably the HV battery pack must have experienced low voltages.
    I don't think the video tutorial would be of any help, seeing that you already had power coming to the dashboard. Well, I don't know what sort of lights you saw, but if it did show the ready sign, and was a weak 12volt battery, replacing it with a new one would ha e solved the issue.
    Was the new battery you installed new? Did you voltage test it under load or...to determine if it held some juice? If it doesn't hold, that tells y you didn't get any lights on the dashboard after replacing it.
    Try checking the battery terminals connections to see if they're well connected.
    There's also a fuse close to the positive battery post. If that fuse is blown, you might have no lights coming on on the dashboard.
    If you ha e done all that, and its still same, could you please post a scanned results of any codes you might have of the car?
    Dxta
  5. my_priuss
    26
    Plano, TX
    WilDavis,
    I couldn't do what you instructed because there is no power at all.
  6. WilDavis
    2,488
    2,149
    49
    No dome (overhead) light when you open the door? What happens when you switch on the lights (twist end of stalk on left of steering-wheel)? Not even a glimmer? Have you checked the fuses?
  7. my_priuss
    26
    Plano, TX
    Hi Dxta!
    I bought the battery new from AutoZone. I didn't do any kind of testing to the battery at all. I saw the fuse you're talking about and will check if it's blown or not. I'm not sure if I can give you the codes since I don't have any scanner. Sorry..
    Thank you for the response. I will let you know if anything happens.
  8. TMR-JWAP
    TMR-JWAP Senior Member
    5,734
    5,568
    Columbia, SC
    Some basic things to check:
    1. Is the battery installed and connected with polarity correct. The negative post of the battery should be toward the back of the car.
    2. Are the positive and negative cables connected firmly to the battery posts. I have seen the positive clamp installed incorrectly, where I could lift it off the post with no tools.
    3. Is the negative cable bolted firmly to the body of the car (bolted to body closer to the back of the car toward the taillight.
    4. Are the wires plugged into the positive terminal clamp assembly? There should be two push in connectors attached to the assembly.
    5. Are you able to use a multi-meter to check the actual voltage of the new battery you just installed?
  9. my_priuss
    26
    Plano, TX
    Dxta,
    The fuse seems to look fine to me. I didn't do check it with any tools though. Just with my eyes. And it seems like the metal in the middle is still connected.
  10. my_priuss
    26
    Plano, TX
    Yeah, nothing. No lights on the dashboard, everything is off as far as I can tell.
  11. my_priuss
    26
    Plano, TX
    I'm sure I installed the battery correctly. I followed everything on the video tutorial I posted above. I wasn't able to check the voltage of the new battery though, since I don't have the tool to do so.
  12. ericbecky
    ericbecky Hybrid Battery Hero
    4,364
    3,208
    Madison, Wisconsin
    Let's start with the dome light.
    Do you have power at the dome light?
  13. my_priuss
    26
    Plano, TX
    Nope, nothing.
  14. Dxta
    Dxta Senior Member
    1,931
    765
    Lagos
    Try getting a digital voltmeter to test the voltage of the battery. Or better still, remove the new battery, and instaethe old one and see what happens. If it brings lights on the dash, the new battery is dead maybe.
    PS: If after replacing the old battery back in the car, and there's mo light on the dash, that means you have am open circuit problem on the 12V circuitry.
    Dxta
  15. ericbecky
    4,364
    3,208
    Madison, Wisconsin
    Double check the voltage of the battery. Either do it yourself, or bring it back to where you got it and have them check it. (most stores will check it before selling it.)
    If voltage is OK, then may need to start checking fuses.
  16. my_priuss
    26
    Plano, TX
    I don't have the old battery anymore. But I remember after disconnecting the 2 cables on the (old) battery (the battery is still connected, I haven't messed around with the battery at this point), I closed the trunk and I couldn't open it from outside. So I had to fold the back seat and reconnect the 2 cables to the battery. I did notice some of the dashboard lights were on and I was able to open the trunk again. Does this tell you anything?
  17. my_priuss
    26
    Plano, TX
    I got it from AutoZone. And they didn't do any testing when I bought it. Should I bring it back and have them do the testing?
  18. my_priuss
    26
    Plano, TX
    Just a heads up, I tested the battery using the multimeter. It says .43. I'm not sure what it means. Is there something wrong with the multimeter or maybe I'm not doing it right? What I did was I turned on the multimeter to 20 V DC and connected the red to the positive and black to negative. If I tested it properly, does that mean the battery is not good?
  19. my_priuss
    26
    Plano, TX
    I tested the battery using the multimeter. It says .43. I'm not sure what it means. I know it has to read something like 12.8x. Is there something wrong with the multimeter or maybe I'm not doing it right? What I did was I turned on the multimeter to 20 V DC and connected the red to the positive and black to negative. If I tested it properly, does that mean the battery is not good?
  20. my_priuss
    26
    Plano, TX
    I tested the battery using the multimeter. It says .43. I'm not sure what it means. According to online resources, it has to read somewhere close to 12.86 V. Is there something wrong with the multimeter or maybe I'm not doing it right? What I did was I turned on the multimeter to 20 V DC and connected the red to the positive and black to negative. If I tested it properly, does that mean the battery is not good?
Loading...
