2004 traction battery says "sayonara" at 316,000 miles
Discussion in 'Gen 2 Prius Technical Discussion' started by stonehome, Sep 19, 2018.
  1. stonehome
    stonehome Junior Member
    24
    16
    North Coventry Pennsylvania
    Returned home from 8 day vacation and had the following error codes immediately after starting up my '04:
    P3009 (HV System Short) with sub codes 526 and 612 (HV battery); C1310 (HV System Malfunction)
    Checked everything per my Toyota shop manuals. Luscious Garage advice on basic isolation steps for these error codes confirmed what I thought I'd already knew, thanks Carolyn!
    System relays measure open to 100 M ohms, all other resistance measurements are fine as well.
    The battery, however, is hanging on to a stray voltage: negative terminal to metal case is 100v, positive terminal to case is about 30v, voltage between the terminals is about 66.
    I repeatedly tried to discharge these voltages with a few light bulbs. Never lit the bulbs so I'm guessing that it's low current from an electrolyte leak between one or more cells and that case, which is supposed to be completely isolated from the battery....
    All connectors are removed from the battery ECU, and battery connectors are removed from the system master relay contacts.
    I'm buying a new battery from my dealer, whose on-line price is about $1600.00 with core exchange.
    Any thoughts or comments are welcomed, however, I plan to get the Toyota OEM replacement since it's now competitive with after-market replacement prices.
    Many thanks: this is far and away the best forum on Prius, with many well informed members, and has benefited me greatly.
    48,995
    nice run!
    if you plan to keep the car, and the rest of it is in good shape, a new oem is the only way to go.
    all the best!(y)
    DLC82SV and Skibob like this.
  3. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    It will be interesting to see if you can get that price. Keep us informed.
    Mendel Leisk and DLC82SV like this.
  4. DLC82SV
    DLC82SV Member
    241
    118
    I was just quoted $1550
    But that's $1950 minus 20% off. I had a coupon in my owners manual from when the car was purchased for 20% off of my first purchase of genuine Toyota parts and or accessories that came with the car brand new. Did anyone else think to keep their coupon in their owners manual for 10 years because it doesn't have an expiration date? I just verified, they will honor it whenever the time comes.
    Skibob and Prodigyplace like this.
  5. Skibob
    2,912
    1,496
    Northern California
    That is fantastic. Where is this coupon located? I have all the original manuals for my car.
    DLC82SV likes this.
  6. Skibob
    2,912
    1,496
    Northern California
    Now that I think of it I have the manuals for a 1993 Camray, 2 98 4 runners, a 99 4 runner, a 2005 Tacoma and my 2006 Prius. There has to be a coupon somewhere in that stack.
    DLC82SV likes this.
  7. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    FYI, the Toyota pack does not come fully assembled.
    Not the same as afremarket drop in packs.
    And buy/rent an inch-pound torque wrench to properly tighten the nuts. Not worth the risk of arcing/fire or breaking the bolts due to under/over tightening.
    Merkey and jerrymildred like this.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    I'm impressed.
    14 years.
    316,000 miles.
    And the journey continues.....
    I could see, world record Prius mileage and ownership years on the horizon.
    James1964 and jerrymildred like this.
  9. stonehome
    24
    16
    thanks to all of you who've replied. I will post updates and plan to order the battery today.
    Skibob, I think the actual price is $1699.70 after core trade in.
    Bisco, I agree with you about OEM parts, more money but utterly reliable.
    (Speed Racer was aired in Philly where I grew up: loved that show!)
    ericbecky, thanks for mentioning a torque wrench, I do own one. You raised a question for me though: I am aware that the OEM battery is not a "drop in" assembly and I'll transfer the ECU and probably relays to the replacement unit. Do you have a short-list of everything that I'll need to migrate to the new unit? I might as well take photos and then start removing the parts needed for the replacement.
    Thanks again
    Skibob and bisco like this.
  10. ericbecky
    4,365
    3,209
    Madison, Wisconsin
    It should be obvious as you go
    Vent hoses
    White plastic vent tube
    Computer end of things
    Black plastic cap
    Metal endplate
    White rectangular endplate clip
    Use all 6 of the new nuts, not the old ones (4 module nuts, 2 contactor nuts)
    Use the new cables and wiring and black plastic cover
    Use the new foam caps
    Prepare core by
    Removing pos, neg, and fuse/plug assembly
    Lay 2 rubber mats over modules before closing case
    Label core with vin, odometer, make/model/yr
    Wrap connectors in plastic bag and tape securely
    Make sure it is inch pound. Seen folks break the module posts by having the wrong tool.
    Big difference between inch point and foot pound.
    Phildo and DLC82SV like this.
  11. DLC82SV
    DLC82SV Member
    241
    118
    Mine was from Larry H Miller and the salesman had suggested putting it in the owners manual. Hopefully if you bought it new you were instructed to do the same. Best wishes.
  12. Skibob
    2,912
    1,496
    Northern California
    Nope 2 things I have never bought new are cars and guns.
    DLC82SV likes this.
  13. stonehome
    24
    16
    An Update: It's not the battery (yet).
    I removed and disassembled the HV battery, discovered a lot of "fuzz" growing on the individual terminal connections. The copper bus bars were black. Completely disassembled and cleaned each set of terminals and associated nuts.
    Removed individual bus bar links and cleaned in hydrochloric acid, followed by a dip in some sodium bicarbonate and water to neutralize acid, followed by a dip and thorough rinse in water. Once re assembled, I had no HV leakage code (or any others:)).
    Also removed and cleaned the battery blower unit....
    However, I'd noticed a connector high up in the right rear quarter panel section with some corrosion on the plastic body, plus the relay for the battery blower was wet, plus there was water on the top of the battery exhaust duct and scattered puddles by the left and right rear floor areas.
    Opened connector and cleaned it, read up on water leaks in the Gen2 Prius, and went for a test drive. At about 38 miles I got hybrid system warnings and headed for home. Long story short the fan blower voltage passes through that connector. One of the wires must have been corroded almost completely away where it's crimped to the terminal. My cleaning finished it off and I traveled for about 38 miles without a blower. Last 5 miles or so I could feel the drive system getting a little rough due to battery overheating (though that code never set).
    Back out driving today, will keep you all posted.
    Question: one PriusChat member gave a seemingly good procedure to seal the leaky welded seams using a marine type silicone caulk. Any personal success (or failure) stories about sealing the seams will be appreciated. Thanks.
    SFO and Mendel Leisk like this.
  14. chelvis
    chelvis Member
    83
    49
    Long Valley, NJ
    Wow, great life span on your battery! I replaced my traction battery a few months back at 288K. I used Permatex Ultra Blue RTV silicone gasket sealer on the weld seams on my '05. I did that last Fall, so far so good. I had a similar issue with water getting in, it pooled near my 12 volt battery. Definitely make sure you clean the surfaces very well prior to application.
    Good luck with your '04. Cheers, tom
  15. ericbecky
    4,365
    3,209
    Madison, Wisconsin
    Sealing that seam is a good idea.
    You local parts store may have a quality automotive grade panel sealant.
  16. stonehome
    24
    16
    Another Update:
    Have had some good results using the Permatex 81730 windshield sealer ("flow-able silicone") recommended by several Prius Chat members. I can only echo their advice: the surface needs to be clean and dry, then the silicone sticks well.
    A garden hose can be positioned, with painter's tape, plastic wedges, etc to direct water into those drain channels formed into the hatch and roof area's metal work, thus eliminating the need for an assistant.
    (My wife is a good sport when help is needed, but had lots of gardening to finish, so I rigged up the hose, and worked sections of each rain gutter to determine where the leaks probably were originating.)
    After a first application of the windshield sealant and 48 hrs cure time, the leaking areas were reduced, however, there were cracks I'd missed, and then re-sealed them.
    Also, the tail light trim to metal areas leave some gaps I think to be too large: passenger side had water incursion only from that area after sealing cracks at or near spot weld seams, so the tail lamp areas were in-filled with RTV type aquarium sealer. I will post photos.
    Meanwhile, NO error codes of any kind after 160 miles of driving. HV battery is charging in a normal predictable way once again.
    Will leak test late tomorrow (otherwise rain is forecast the following day and that should tell the tale.)
    Thanks to ALL forum members who gave / posted information, both in this thread and the several threads about causes and fixes for Gen 2 chassis water leaks.
    SFO likes this.
  17. stonehome
    24
    16
    (Final?) update: 3 hours under a lawn sprinkler's arc, plus 2 torrential downpours, and all previous leaky areas are still dry. About 500 miles into a much cleaner, dryer and more tightly connected traction battery. Here are 2 groups of pictures; first are traction battery disassembled and cleaned, second are shots of the sealed seams (Permatex windshield sealer) and tail light assemblies ( DAP 100% silicone Household Sealer ) plus the "mouse-proofing" screens (shown by 2009Prius on June 21 2010). For these I used hardware cloth and sealed entire perimeters with Lexel clear sealant.
    Thanks again to everyone for information and advice.
    #17 stonehome, Oct 13, 2018
